Fuel Filter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-29-2011, 01:46 PM
KAGE KAGE is offline
Vehicle: 94 dodge ram
KAGE is on a distinguished road
Default Fuel Filter
Hey guys. This will probably be a simple question. 94 cummings 2500, leaking diesel. Drained fuel from old fuel filter with water release valve. Replaced filter. Truck will not start. I'm sure i'm missing some step in priming the fuel system or something? If I push the valve on the new filter fuel will come out so I know fuel has gotten that far.
Thanks in advance.
Old 01-31-2011, 12:59 AM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Turn the key to the on position, then to the off position, and do that a few times to allow the fuel pump to cycle. After 5-6 times of cycling the pump, it should start...
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 03-25-2011, 02:28 AM
RamTrucker RamTrucker is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
RamTrucker is on a distinguished road
....or loosen the bleed bolt on top of the housing (where the fuel filter attaches), then press the black rubber fuel priming button (next to the bleed bolt) until no more air comes out (only fuel)...
error code list moparmike07 Dodge Ram Knowledge Base 17 12-01-2017 11:12 PM
New Fuel Filter For 6.7 CTD RamTech LD RAM - General Discussion 4 09-29-2010 04:15 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 08:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
