Old 01-29-2011, 05:07 PM
beerad4's Avatar
beerad4 beerad4 is offline
Trim Level: TRX4
beerad4 is on a distinguished road
Default Tire Pressure
Hey Guys-relatively new to the site. I searched for the topic of tire pressures, but the posts I saw really didnt answer my question. So here goes..
I have 17 stock rims/tires and am curious if anyone has increased their pressure past whats recommended (35psi on door). I was thinking of 38-40..not sure if this would be wise or not..Thanks for your help!
Old 01-29-2011, 05:15 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
the pressure on the door usually gives a smoother ride, but i like it higher for better fuel milage. i usually split the difference between that number and the max on the sidewall mine also are 17" 35 on the door 50 max on sidewall i've got them with 42 lbs now
Old 01-29-2011, 07:14 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Never go beyond the MAX pressure on the sidewall of the tire because when your tires heat up the amount of air will increase on it's own.
You will change tires throughout the life of the vehicle so you can't always check back to the door sticker. The sidewall ratings are specific to that given tire instead of the generality of the door sticker. I have three vehicles with three different tire ratings. I can't remember them all so I check the tire every time I check the air pressure.
www.beatcraigslist.com - for posting dangers & secrets
Old 01-29-2011, 07:24 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im past the 35 psi mark right now because from where its so cold here it keeps setting off my tire pressure sensor in my wheels so i put mine up to i think its 38psi just so it doesnt keep setting it off so yes you can go past the recommended door sticker pressure but you will get a rougher ride and like someone else here mentioned NEVER go above the max number thats on the tire
Old 01-29-2011, 07:32 PM
therock2086's Avatar
therock2086 therock2086 is offline
Trim Level: Big Horn SLT
Color: Deep Water Blue Pearl Coat
therock2086 is on a distinguished road
yea just stay at max, you'll be fine
Old 01-29-2011, 07:34 PM
I agree. The door sticker is a suggestion. The max psi amount stamped on the tire is not to be exceeded.
Just understand that over inflation will accelerate wear on the center of the tread.
Old 01-29-2011, 07:44 PM
beerad4's Avatar
Trim Level: TRX4
Thanks Guys! Big Help!..
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Incorrect door sticker tire pressure recommendation steve57 2010 Dodge Ram Forum 48 09-29-2010 10:38 PM
BS Lag with the Tire Pressure light and HIDs!! YamiCaru Custom Dodge Ram Interior and Exterior Lighting 7 09-17-2010 12:38 AM
TPMS Tire Pressure Monitor Light 2010 351 Stang 2010 Dodge Ram Forum 6 08-28-2010 12:59 PM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 12:41 PM
