Old 07-07-2011, 04:54 PM
NolaRam's Avatar
NolaRam NolaRam is offline
Vehicle: 2009 Ram 1500 Crew Cab TRX
Trim Level: TRX
Color: Detonator Yellow
Rep:29
NolaRam is on a distinguished road
I'd say its hard to measure what an engine is really putting to the wheels at that low rpm because the converter hasn't fully locked up yet and most dynos are advisedly to be run at 3rd or 4th gear pulls with the hard pushing at 2800 to 3000 rpms and up. Otherwise, yes, you'll burn the tires on the knurled rollers and possibly cause other undesireable results, pop a strap, kicking the tires, hopping, etc. Looks like you're on the road to getting it on the road. Congrats. On 93 octane I expect we'll be able to get 14 degrees of timing safely with good rich air fuel across the band at WOT.
Old 07-08-2011, 12:44 AM
NolaRam's Avatar
Trim Level: TRX
Rep:29
Update, some more photos. Its installed, just need to add the water wetter and water to the heat exchanger and then the base tune from the manufactuer to load up and begin fine tuning. Let's hope its ready for the weekend.
Breathe....
Pulley clearance from A/C lines
Looks like it belongs there.
Old 07-08-2011, 06:12 PM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
Breathe....
thats the best part they look it should have always been there
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
Old 07-08-2011, 11:10 PM
NolaRam's Avatar
Trim Level: TRX
Rep:29
Yes. Ran it on the dyno with the base tune. An anemic 291 that felt just like stock, with plenty of fuel dumped into the base tune. Some leaning and timing adjustments later, 366 hp. Its still rich in the 10s, and not looking to push the timing too much, so would be happy with 380 to the wheels. The 30-80mph come on is very nice and noticeable improvement from the stock performance and the mds still engages on the highway. Good unit. I imagine the 8 lbs pulley would be even more enjoyble. currently seeing 5.5 lbs.
Old 07-08-2011, 11:29 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I'm sure you guys are shooting for an a/f in the upper 11s but are you really only going to run 14 degrees timing? do you mind if I ask why so low? 16-17 degrees is still really really safe with 93 octane...
not criticizing just asking.
Old 07-09-2011, 12:11 AM
Trim Level: laramie
Rep:21
they are tryin to my af 11-12.5 area. and they see about 8.4 lbs on the first vid i posted. and thats with a smaller than 09 pulley not sure if they use 07 or another but i have smaller heads. the pulley confiq i had put to much air could not put enough fuel in at topend.
now i have good fuel at wot just not any where else. now no more tuner tuning via unichip wiring harness and computer
Old 07-09-2011, 01:20 AM
NolaRam's Avatar
Trim Level: TRX
Rep:29
Depending on where they sample the air, usually exhaust air fuel is a little leaner than a bung location directly in front of cat, in my jeep by about .8. Understand about the fuel. 11.5 at the muffler probably means about 10.6ish at the bung.
Maybe use the CMR software for tuning? That seems to be what most use, picking up the pids (including the MAP) from the OBDII and the a/f from the muffler.
I figured I'd make closer to 400, so some disappointment, but it is faster so am enjoying the upside.
Old 07-09-2011, 01:38 AM
Trim Level: laramie
Rep:21
they are doing a full custom tune of everything with the unichip af map ignition rev limit
live dyno tuning it should be good
the lean out under normal driving conditions is there major concern right now.
i will buy an wideband soon as i get her back already got the boost gauge
Old 07-09-2011, 07:45 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Yeh its all in the tune just takes some time... Im currently at around 11.8 to 12.4 for my AFR with my hemifever tune
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-29-2011, 09:32 PM
Trim Level: laramie
Rep:21
sitting at 420rwhp and 405 rwtq warm and 450wrhp 420 rwtq cold
400tq as soon as you hit the gas and across the entire power band it never drops below and that with at 8.5 lbs.
the 09 pulley gave me 10lbs but the motor could not handle it.
Taking on a Corvette with a Hemi Ram... any suggestions? RAMpage Kills and More Kills 32 04-25-2011 02:05 AM
06 5.7 hemi 1500 Magna or Flow? yam700 Exhaust 9 08-06-2010 06:00 PM
Turbo Hemi Ram vs. Supercharged Ram SRT-10 JK04Ram1500 Off Topic Discussion 16 01-29-2010 01:04 AM
Look!!!! It's a supercharged 1500 hemi!!!!! dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 9 10-07-2009 01:34 AM
