SuperCharged Hemi RAM thanks to Magna Charger - Page 18 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 07-29-2011, 09:16 PM
skwurlz skwurlz is offline
Vehicle: 2014 RAM R/T
Trim Level: R/T
Color: Maximum Steel Metallic
Rep:20
skwurlz is on a distinguished road
So you swapped out to the 3.8 pulley? 400 RW LB/FT is pretty damn good.
2014 R/T, Magnuson TVS1900, K&N Filter, MBRP Muffler back exhaust, Belltech 2/4 drop, Spohn track bar, 511RWHP, 50 state legal. 12.66 1/4 Mile @ 109mph
Old 07-29-2011, 11:31 PM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
Nope it is a stock 07 pulley with 09 pulley system on 07 ram motor. our heads are smaller is the reason i am almost sure. 09 pulley put 10 lbs in the motor..
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
Old 08-02-2011, 12:21 AM
Trim Level: R/T
Rep:20
Huh? That didn't make any sense. There is no "stock 07 pulley" for the truck supercharger, unless your refering to the 5.7 car blower pulley. Which is still a little confusing. The blower should have either a 3.4" (doubt yours does as this is for the 6.1L) 3.6" or 3.8"
Whats the Diameter on your blower pulley, or better yet, just post up the 9 digit Magnuson part #.
Mucho appriciado
Old 08-04-2011, 11:23 PM
Trim Level: laramie
Rep:21
Mucho appriciado
i was going off his words until i found the spare pulley for the S/C it's self
3.400 comes with the 09 ram s/c kit
the one i have is it look like 3.7 P/N 570006037 looking at my receipt
on another Note
she runs great not leaning out but i dropped 3rd 4th and 5th gears and it look electronic right now gonna take it to dodge and see if i can warranty an engine with 31k mile. the truck thinks it is in gear and just revs.
Old 08-04-2011, 11:59 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Sorry to hear about your trans problems but did I understand correctly? You are going to take your supercharged truck into the dealer and ask for it to be warrantied?
I hope you have a friend up there who will hook you up.
Old 08-05-2011, 08:47 AM
Trim Level: laramie
Rep:21
They have to prove the aftermarket part broke the tranny, if it is electronic I should be fine. Tranny replace I won't be able to get away with. And 31800 mile 200 with the s/c after they finished. The shop thinks is a sensor failure the computer thinks it is in gear. And it just revs. If it is a tranny ats is my next purchase
Old 08-05-2011, 09:05 PM
CHVYKLR's Avatar
Rep:252
I know the law but only if it were that easy. What I've seen happen is someone brings in a mod'd vehicle and the dealership says that becuase you did this mod the warranty is voided and we aren't going to cover it.
What do you do at this point? Once they turn you away how do you get them to work on your truck? Now it's on you to prove to them that your mod wasn't the cause and that they should honor the warranty. do you really think they are going to run tests and spend money to prove to you that a mod was the cause. No, all they have to say is no we aren't doing the work and then the ball is basically in your court.
I really hope it works out for you. I've been amazed at some of the leniency of some dealerships from stories I've seen posted on other forums. I would suggest getting all your info together before going in. That way if they do say no you can ask for the service manager and present your case.
Old 08-05-2011, 09:23 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Thats a busted tranny... what code is it popping? cause that sound exactly what happend to me. Its a reverse shaft thats probably the issue no issues in the reverse gear tho.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 08-05-2011, 10:30 PM
mgh's Avatar
mgh mgh is offline
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
I had the same problem after dynoing my twin turbo setup. It turned out that I cooked the overdrive frictions.
Old 08-06-2011, 01:23 AM
Trim Level: laramie
Rep:21
po733 p0734 p0735 and i will try for the warranty or go ats
Taking on a Corvette with a Hemi Ram... any suggestions? RAMpage Kills and More Kills 32 04-25-2011 01:05 AM
06 5.7 hemi 1500 Magna or Flow? yam700 Exhaust 9 08-06-2010 05:00 PM
Turbo Hemi Ram vs. Supercharged Ram SRT-10 JK04Ram1500 Off Topic Discussion 16 01-29-2010 01:04 AM
Look!!!! It's a supercharged 1500 hemi!!!!! dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 9 10-07-2009 12:34 AM
