Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-30-2011, 03:18 AM
leon leon is offline
Vehicle: 2004 Dodge Ram
Color: Arrival Blue
leon is on a distinguished road
Default Surged & Died
Just after I started my 2004 5.9 today I experienced some surging. (different from the light throttle trans gear hunting issue that has the TSB out on it) Then when I got to the stop sign at the end of the street it died and wouldn't refire. The temp was about 75. The lift pump ran for about 5 seconds each time I cycled the key but no start. I drained the water separator and fuel came out. I had about a third of a tank of fuel per the gauge. I went home and got some more fuel from the tractor and added a gallon. Not because I believed it was empty but because it was easy to rule out that way. After I added fuel, still no start.
Then I held the throttle open about a third while cranking and it started. It idled roughly for a few seconds similar to a flooded gas motor, then settled down and ran fine for the 11 mile trip to the store and back. Now I don't know what to think. Is there any common problem I can look at? Anything I can test to renew my confidence in the truck?
This is my 1st diesel, so I feel a little uncomfortable with unexplained behavior.
Thanks for any input.
regards,
Leon
Old 01-30-2011, 01:46 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Leon, my guess is that your lift pump is starting to fail. My truck did the exact same thing before the lift pump died completely. The dealer now has an in tank pump retrofit that they do for our trucks. This is all based on the assumption that you still have the stock engine mounted lift pump... is that correct? If so, my guess is that the LP is going south.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-12-2011, 08:30 AM
Color: Arrival Blue
It's gone about 800 miles without a repeat performance. I believe I have the in-tank fuel pump. At least I don't see it on the back of the filter. I haven't let the fuel level get below 1/2 tank though either. In my reading, I found references to a "quarter tank fuel starvation" problem with our trucks. But I could find enough info to understand what exactly it was or where it applied. Anyone have an explanation?
regards,
Leon
Old 02-13-2011, 05:12 PM
Rep:93
Hmm interesting. I haven't heard much about the quarter tank fuel starvation problem.. I have run my truck to below 1/4 tank many times and never had an issue.
Scott
Old 03-15-2011, 03:32 PM
Midnight's Avatar
Midnight Midnight is offline
Vehicle: 2004 Doge Ram 2500 Cummins TD
Trim Level: SLT Laramie
Midnight is on a distinguished road
Send a message via MSN to Midnight
My 2004 did this last month...turned out to be the TPS (Throttle Positioning Sensor)....$700.00 at the dealer for just the part. New TPS and now running strong
HVAC controle module died, please help kot333 2010 Dodge Ram Forum 3 01-08-2011 11:09 AM
Truck died in the middle of the road DieselD24 Cummins Diesel Specific Topics 7 12-22-2010 10:58 AM
Truck died! Gossage55 5.2L V8 Specific Topics 6 12-07-2010 12:28 PM
Another Ford Died today! Butter Kills and More Kills 11 11-07-2010 09:26 PM
My Skyline before it died Dann Off Topic Discussion 7 12-28-2009 03:39 PM
