Old 01-30-2011, 01:00 PM
dirtrider29's Avatar
dirtrider29 dirtrider29 is offline
Vehicle: 2007 Dodge ram
Color: mineral grey
Rep:15
dirtrider29 is on a distinguished road
Default ram acting weird
Whats up guys last night i went to go get gas at hess because i was on an 1/8 of a tank so i filled up and went to leave. When i pulled out i stepped on the gas and it wouldnt go above 1000 rpms even when i would put it to the floor nothing would happen it would just bogg down so i went home shut the truck off and turned it back on and everything was fine. I was wondering what could have caused that. I was thinking maybe from running the tank down so low and sucking somthing up to the fuel filter. Any ideas of what could have happen?
Old 01-31-2011, 10:42 AM
Rep:1909
A clogged strainer isn't my first guess. Did any dash lights come on when this happened? I'd be more inclined to suspect an electronic throttle control problem. Have the PCM scanned and see if there are any related codes.
Old 01-31-2011, 11:56 AM
hemidoc's Avatar
hemidoc hemidoc is offline
Vehicle: 2003 Dodge Ram 4x4
Color: Blue
hemidoc is on a distinguished road
if it doe's it stop the truck put in park turn off whait a second or two and restart it will reset if it keeps doing you will have to take it to the dealer and have the THROTTLE POSITION SENSOR replaced, the Generation 3 Ram hemis where known for this problem and Dodge really don't have an answer for it
Old 01-31-2011, 12:25 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
that suxs dude and sorry i cant give you any input on this but hopefully you will get it all figured out soon.
Old 02-05-2011, 07:06 PM
Color: mineral grey
Rep:15
Thanks a lot guys. Once i turned it off and waited a second and then turned it back on it has been fine for the last week with no problems. But now all the sudden i was sitting at a stoplight and my check engine light went on. I called the dealer about it and they said to give it a couple days to go off and if not come in. He said that if the check engine light starts blinking than ive got a problem. truck is driving perfect though?
Old 02-05-2011, 07:15 PM
Rep:1909
That dealer must be doing a helluva business to tell you something like that.
Old 02-05-2011, 07:35 PM
Color: mineral grey
Rep:15
Idk man i thought i should get it checked out to and they said give it a couple of days if it doesnt go off then come in and well check it out
Old 02-05-2011, 08:43 PM
cosbourn's Avatar
cosbourn cosbourn is offline
Vehicle: 2004 Dodge Ram QC 4x4
Rep:83
cosbourn will become famous soon enough
the guy you prolly got a hold of at the dealer had the 'ole "loose gas cap" in mind when he told you that. These damn vehicles now a days require perfect fuel tank vacuums or they throw codes. After owning 2 rams for a combined 4 and half years, the only time my check engine light has come on was for a "loose" gas cap.
in your case however, this is not the case and the above input should point you in the correct direction. I would definitely think about getting your PCM checked for anything that might track the problem down for yah.
ga'luck!
Westin Ultimate Bull Bar w/ IPF 968CSG lights, Husky Mud Flaps, Bedlined GoRhino Dominator II steps, Bedlined Fuel Door, RBP Pedal-Covers, Clarion CZ300, Composite BFI (#71) w/ 8" Tall Amsoil Filter + K&N Drycharger Prefilter, AirRam Scoop, Flex-a-Lite 183, dumped Aeroturbine 3030XL
Old 02-07-2011, 05:36 AM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
bad fuel maybe, i got bad gas from Hess a couple weeks ago and mine did the same as your but it would stop at 3k. put a fuel addative in it and i havnt had any problems since. but idk about that check engine light.
"I'm your huckleberry" (Doc Holiday)
Old 02-15-2011, 01:09 AM
THasse THasse is offline
Vehicle: 2012 Ram 1500
Color: Dark Red
Rep:44
THasse is on a distinguished road
I had that happen to mine once. As you did, I shut it off, and it worked fine again. Later had a check engine light come on (a while later), I flashed it and it's just the sensor on the egr valve, $40 bux. Haven't fixed that yet cuz it isn't affecting the truck much really. Something to look into though. Hope that helps...
Mods: Deleted Resonator, painted talgate logo, DiabloSport tune, K&N drop in. Plenty more on the way, finances permitting...
03 Dodge Ram Diesel Weird Noise sawyersd Cummins Diesel Specific Topics 3 02-11-2012 12:59 PM
a/c acting weird... strang3majik Heating & Cooling 7 09-02-2010 10:38 PM
Weird noise coming from pulley? MrCantu 4.7L PowerTech V8 Specific Topics 14 01-10-2010 12:19 AM
Directionals Acting Up BostonRam03 Electrical 5 11-18-2009 10:53 AM
Fuel gauge needle acting up bleep Electrical 2 09-05-2009 07:24 AM
