Old 01-30-2011, 01:14 PM
ronrrp's Avatar
ronrrp ronrrp is offline
Vehicle: 2007 Ram 1500 Megacab 4x4
ronrrp is on a distinguished road
Default Serpentine Belt Still Squeals!!!
1999 Dodge Ram 1500, 5.2 Magnum
Replaced the belt 4 times in the past month along with the following:
Idle pulley
Fan clutch
Belt tensioner
Power Steering pulley
AC compressor, clutch (6 months ago)
The belt still squeals! This is driving me crazy, the garage has no answer... As soon as you get the belt wet (just a couple of drops of water) the squeal stops for 20-30 seconds...
Old 01-30-2011, 01:19 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Is it to tight or to loose? Is it the right belt?
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 01-30-2011, 01:20 PM
ronrrp's Avatar
Its the right belt, how do I tell if its too tight or loose? I thought the auto tensioner does that?
Old 01-30-2011, 01:37 PM
BLKSVT's Avatar
Rep:222
Could be one size smaller belt or one size bigger...I know I ran in to this issue one time.
Old 02-05-2011, 03:01 PM
Piladeal Piladeal is offline
Vehicle: 1999 Dodge Ram Sport 4x4
Color: Yellow
Piladeal is on a distinguished road
Default Yep....
I have the same problem, sounds like a bird is chirping in my engine compartment and its worse when its damp outside. I replaced my tensioner and belt and it went away for a day and sure enough the "birds" came back to the nest....Drives me F-In crazy......Im ready to replace every pulley etc. on the engine until I find it!!!! H E L P..........
Old 02-17-2012, 10:48 PM
s.rasinskis s.rasinskis is offline
Vehicle: 2000 Dodge Ram 1500 3.9
s.rasinskis is on a distinguished road
I have the same problem on my 2000 Dodge Ram 1500 pickup with 3.9.
I put gatorback belt on, idler, tentioner pulley, fan clutch, and even replace p/s pump with new pulley.
Come to find out it is glazed. Take wire brush too all the pulleys and do belt lightly. It works.
Old 02-19-2012, 12:44 AM
MaleNurse MaleNurse is offline
Vehicle: 2006 Dodge Ram 1500 SLT 4x4
Trim Level: SLT Big Horn Edition
Color: Charcoal
MaleNurse is on a distinguished road
So, the pulleys and the belt are glazed? And you say wire brushing them is the answer? I didn't feel any glaze on my pulleys when I removed them.
If its just some kind of glaze then it isn't harmful?
Old 02-19-2012, 01:07 AM
BLKSVT's Avatar
Rep:222
Just another thing here my 2010 was just having this same issue, the dealer under warranty replaced the belt 3 times, a tensioner once...the other tensioner the next time...then finally one guy found it! The water pump was squealing...new pump wallah! problem solved
Old 02-19-2012, 07:18 AM
dusted72's Avatar
dusted72 dusted72 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
dusted72 is on a distinguished road
I had a similar issue with my 00 5.9. I replaced the water pump and belt then it started doing it so I pulled the pump off and replaced it under warranty. I figured there is no way it could be that expensive belt, it was somewhere around $50 at the time. Sure enough it was the Gates belt, they are made from a very stiff/hard rubber. I switched to a Goodyear Gatorback and it solved the problem, the ribbed surface has a pliable softer rubber that is supposedly garanteed against squeeling. I will never buy anything but the Gatorback ever agian.
Explosions are cool.
Old 02-19-2012, 08:51 AM
tfs2403 tfs2403 is offline
Vehicle: 1996
Trim Level: slt laramie
Color: blue
tfs2403 is on a distinguished road
Hi guys,
I hope I can be of some help....I had a F*** doing the same thing. We replaced the belt with the least expensive available, cleaned all the pulleys with brake cleaner. Still sqeeked like crazy. We tried everything and eventually went out a bought the higher end belt (Most expensive) and it stopped.
Our expeirence was after dealing with coolant issues and after resolving those issues is when the squeel became louder. Coolant probably got on the belt system at some point and ruined the belt. adn cheap belts (I have been told) tend to squeel.....
Good luck guys
Robb
belt, belt noise, squeak, squeal
Serpentine Belt Diagram billhereford@cableone.net Cummins Diesel Specific Topics 3 02-20-2011 10:15 PM
Serpentine belt diagram... ArmyofOne 2009 Dodge Ram Forum 5 01-17-2011 06:54 PM
Serpentine Belt Question KhaosTheory 5.9L V8 Specific Topics 1 05-19-2010 09:15 PM
Squeak From Serpentine Belt 1970swbc10 5.9L V8 Specific Topics 2 04-04-2010 11:22 PM
Goodyear Gatorback serpentine belt? Kens04 Dodge Ram General Discussion 10 02-20-2010 04:06 PM
