Old 02-23-2012, 07:58 PM
Alfisto Steve Alfisto Steve is offline
Vehicle: 2000 Dodge Ram 1500
Color: PRV
Alfisto Steve is on a distinguished road
Just went throught the same exercise. Replaced Dayco cross-hatched belt Jan 10.
New Dayco ribbed belt lasted about two weeks before noise driving us crazy so I replaced water pump and tensioner puller and idler pulley and reinstalled the Jan 10 new Dayco ribbed belt. Same "frapping" aka f_igging noise.
Reinstalled original tensioner and idler pulleys same noise. I took belt back and got a new one under warranty same Dayco part number as they don't carry Gatorback belt.
So far new softer kinder gentler Dayco belt whisper quiet. Wish me luck hope it was belt and now I have a spare used water pump.
Repair shop I use only for my state inspection stickers told me today they stopped using Dayco belts and only use Goodyear Gator backs as they had some many customer complaints with Dayco belts. However, none of the parts store around here sell GY belts.
Old 02-25-2012, 05:41 PM
.Seth. .Seth. is offline
Vehicle: 98 ram 1500
.Seth. is on a distinguished road
Water pump....
I had the same issues, check the clutch fan and see if it wiggles, if it does then its the water pump
Old 03-08-2012, 08:02 PM
clive hart clive hart is offline
Vehicle: 1997 Dodge Ram
Trim Level: st
Color: silver
clive hart is on a distinguished road
My 5.2 Ram had a squeeky belt. Put a new Gates one on and the noise went away for a while. The next time it got wet the noise came back. A temporary cure I got from a Ford mechanic was to sprinkel talcom powder over the belt. The noise will go for the rest of the day but you will need to do it every new day. It can make a bit of a mess in the engibe compartment and I dont supose you want too much powder in the altenator. If the powder trick works it cant be the water pump surley. Maybe I should get one of those Good Year belts that has been sugested.
Old 03-10-2012, 08:59 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Also I've not herd one person mention a forgoton pully as an issue the alt pully. Mine was that new alt belt and tenchener pully later quiet as a mouse.
Old 12-02-2014, 02:57 PM
Kentuckyboy Kentuckyboy is offline
Vehicle: 2010 dodge ram 1500
Color: Light graystone pearlcoat
Kentuckyboy is on a distinguished road
Were these squeals and squeaks upon start up and then goes away? Cause my 2010 just started making a squeak noise like a belt would if it is wet. It has rain the past
Couple of days and been foggy out but it shouldn't be squealing today but it did then goes away after I drive off? Anybody know what this could be, as if I thought the dodge engine tick was bad enough now this.
Old 12-02-2014, 04:54 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'm sorry if I missed something I didn't read the whole thread.
Did you check the pullys? Tensioner and idler? The belt might be getting worn. Also if it's cooler out than it's been a belt can make noise until it warms up since it isn't as pliable.
Old 12-03-2014, 01:40 PM
Brewtus Brewtus is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Rep:25
Brewtus is on a distinguished road
Holy thread revival!
How many miles do you have on it? Belts can go hard over time depending on how much heat they're exposed to. When you pull the belt off to check pulleys, I'd go ahead and replace the belt. They're not that expensive. Then you can throw the old belt in a tool box or under a seat. It may squeal, but if you lose your belt out on the road, it can at least get you home.
Brewtus
KCCO and Keep it Dirty
Old 12-05-2014, 10:14 PM
Lazarus Truck Lazarus Truck is offline
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Just to throw gas on the fire, I had a recurring belt squeek/squeel on my 01 Stratus. Replaced two ps belts, adjusted the serpentine a zillion times. Turned out the A/C compressor pulley bearing was going! That was the drag, and the squeal. The bearing itself didnt make a noise, just the belt-drag on the pulley. So, check the feel of the a/c pulley bearing.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 01-13-2015, 07:59 PM
TexasOutlaw TexasOutlaw is offline
Vehicle: 2001 Magnum
TexasOutlaw is on a distinguished road
Talking Just to be sure...
I think i would touch test feal out each pulleys berrings. if they spin fast or make noise, or grind, then that would be the culprit. Alot of things could make it do that so im not going to tell something just because mine did it. Makes no sense.
I had a leak in my radiator once and when it would get low, i could hear the pump squeeking. When i filled it back up it would almost go away. But then it eventually went on out. IDK if that could be it but its worth a shot eh?
Old 01-16-2015, 10:47 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Don't forget pulley alignment.
belt, belt noise, squeak, squeal
Serpentine Belt Diagram billhereford@cableone.net Cummins Diesel Specific Topics 3 02-20-2011 10:15 PM
Serpentine belt diagram... ArmyofOne 2009 Dodge Ram Forum 5 01-17-2011 06:54 PM
Serpentine Belt Question KhaosTheory 5.9L V8 Specific Topics 1 05-19-2010 09:15 PM
Squeak From Serpentine Belt 1970swbc10 5.9L V8 Specific Topics 2 04-04-2010 11:22 PM
Goodyear Gatorback serpentine belt? Kens04 Dodge Ram General Discussion 10 02-20-2010 04:06 PM
