Old 01-30-2011, 03:49 PM
jaydubbz1019 jaydubbz1019 is offline
Vehicle: 1999 ram 2500
Color: met. red pearl
jaydubbz1019 is on a distinguished road
Send a message via Yahoo to jaydubbz1019
Default no heat, blower motor works when jumped
i have a 99 dodge 2500 and the heater was working off and on. now has completely stopped. i jumped the blower motor and it is working but i'm not getting a change from the knobs just one constant flow of warm air.all the settings for floor, defrost, ect. work. any ideas what the problem is and how to fix pls?
Old 01-30-2011, 07:02 PM
AJ1500 AJ1500 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: standard
AJ1500 is on a distinguished road
sounds like the speed reastat is bad, that controls your different speeds
I'm not sure where it is but it's prob close to the motor. what you want to do is find it then check it for getting power from the fan switch in all speeds, if you have power then the reastat is bad. if no power is coming to it then it may be the switch
of course you have checked fuses,, right?
Old 01-31-2011, 07:33 AM
yes i have check the fuses. are you talking about the resistor?
Old 01-31-2011, 09:06 AM
Yeah I meant resistor, if the power is working to it at all speeds from the switch but not leaving it then it is bad
if there is no power then you have to back up towards the switch
also make sure your grounds are good, somtimes grounds can do weird things
Old 02-07-2011, 12:16 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
The resistor is located underneath the dash, by the blower motor.
Old 02-07-2011, 01:35 AM
Rep:2705
troubleshooting help can be found watching the HEATERTREATER videos
http://heatertreater.net/Dodge%20Product%20Page.htm
Heat on one side only mopar02 Electrical 13 07-01-2011 12:22 PM
AC blower problems mcline1968 Heating & Cooling 4 12-22-2010 11:34 AM
Little Heat NCDEVILDOG Heating & Cooling 1 12-08-2010 09:11 AM
2001 Ram with no heat precioushwc Newbie Checkin! 7 11-04-2009 09:35 AM
