Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 02-24-2011, 01:48 AM
Rep:2657
as i mentioned, i have a Class 4, came with the truck
my build sheet reads
XFH Class 4 Receiver Hitch
i also have
NMCP Heavy Duty Engine Cooling
NHDP Heavy Duty Transmission Oil Cooler
Old 02-24-2011, 02:02 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Originally Posted by Spartan7G09 View Post
I guess it's personal preference, but I just can't see how that small receiver is going to be as strong as one that mounts directly to the frame.
The bar that it is bolted to is mounted directly to the frame. It is a very strong setup and is what Dodge will provide as the factory option. Just look at the specs...If you use a weight distributing hitch, it's rated for a 10,000 pound trailer and 1000 lb tongue weight. If your towing anymore than that, frankly maybe you should get a 2500. I used to work in the RV industry. Trust me, a class III hitch is more than plenty for most applications.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 02-24-2011, 12:15 PM
Spartan7G09 Spartan7G09 is offline
Vehicle: 2011 Dodge Ram
Color: Inferno Red
Rep:30
Spartan7G09 is on a distinguished road
The option that is being offered by these places is NOT the factory offered option, at least it wasn't in the case of my dad's truck. He got a square tube, frame mounted Class IV hitch on his truck. I agree that if you go over that weight, you should consider going with the 2500, but it's nice to know that if I NEED a Class IV, it's there, and considering that everywhere I've looked, the Class III and Class IV is the same price, it only makes sense.
Old 02-24-2011, 01:08 PM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Originally Posted by ArmyofOne View Post
can I even mount one directly to my frame? it would appear that bar is in the way. Sucks because I have a frame mount class IV in my garage, its a Universal Reese that came off an F150. I can weld, so should be no issue , but I am NOT cutting that crossmember off to do it, so what gives?
The front center of the Class IV hitch mounts to the back of the rail with two bolts, just like the Class III hitch does and the receiver hangs below the rail and the bumper. The Class IV also has two bolts going to the frame on each side of the truck. The class III has an additional single large bolt through the bumper ball mount hole to give it a 3 point mount. The class III is avaialble at Amazon for $72 shipped.
Old 02-24-2011, 01:12 PM
Rep:30
The trucks with hitches I looked at on my dealer's lot have the same Class III hitch I have. Curt claims this is an OEM style hitch. I bet Chrysler offers both hitches as options.
Old 02-24-2011, 02:22 PM
Rep:147
True, or the dealer could have had a local truck shop install the class IV hitch, like my dealer offered. I wanted the oem style so I ordered it. That small center section like I have IS the oem option. Go to dodge and take a look at the pic in the parts book.
Old 02-25-2011, 12:25 PM
ELFATKAT's Avatar
ELFATKAT ELFATKAT is offline
Vehicle: 2011 Dodge Ram 4x4
Rep:30
ELFATKAT is on a distinguished road
Cool I think I understand the towing equation
So we have a small class III receiver hitch that is attached to the cross member under the truck. This in essence means that the small part you wold buy from drawtite, hidden hitch, etc... like having one of the larger hitches that come with a cross member and brackets that attach to the frame. The limits come to play when you use a load distribution hitch that is something that you can slide into the receiver. That hitch increases the limit of total GVWR for the trailer you can tow from 6000 to 10000. The engine and tranny can handle up to 10525 or something like that.
I just want to make sure that I can pull the trailer that I want to buy. I also do not want to spend too much money on a receiver hitch if I do not need it. I am pretty sure when I want to trade up to a bigger trailer I will also trade up to a 2500 cummins.
Sorry if I hijacked your thread. Maybe I will repost, but this is what I am planning to do. Those of you with more knowledge let me know if I am correct.
Install Class III reciever hitch like this one...
http://www.etrailer.com/Trailer-Hitc...eid=2011300060
and buy a load dist hitch like this one...
http://www.etrailer.com/Weight-Distr...ies/49569.html
and pull something like a travel trailer up to 10000lbs
Does that make sense?
ELFATKAT
Carlos "ELFATKAT" Medina
www.carlostmedina.com
Old 02-25-2011, 12:58 PM
Rep:30
ELFATKAT
You are correct. As long as you don't go over 10k lbs you will be good to go. Don't forget to verifiy the tongue weight of the trailer too. The class III receiver is rated for 1000lbs but the dist hitch you linked is only rated to 800lbs. BTW, the Curt 13333 hitch is avaialbe at Amazon for $72 shipped.
Old 02-27-2011, 08:07 PM
ELFATKAT's Avatar
Rep:30
Thumbs up On it's way...
Thanks for the tip I ordered the curt one you mentioned from Amazon. I also had an unused credit so I got it for $60
I will post pics once I install it...
ELFATKAT
Old 03-01-2011, 01:54 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
You must not have understood me. I have a weight distributing trailer hitch (Class IV) that I want to put on my Ram. Can it be done? or is that support in the way? If not I am only out $5 (what the hitch cost me at a yard sale) and I suppose I could pop for the one from Amazon. I just need to know if I can use the one I have or if I need to pass it on to someone who can use it.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Finally bought my new 2011 dodge!! earlzie 2011 Dodge Ram Forum 30 02-25-2011 05:28 PM
2011 Dodge Ram R/T booster Newbie Checkin! 15 12-20-2010 09:42 PM
Chrysler takes the wraps off of 2011 Dodge Durango DaveDees Automotive Industry News and Dodge Press Releases 12 09-08-2010 05:43 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
dodge ram cummings deisel towing hitch???? supernan1414 Towing 3 05-03-2009 07:56 PM
