Old 01-30-2011, 06:18 PM
luv2gomudn's Avatar
luv2gomudn luv2gomudn is offline
Vehicle: 98 Ram 1500 4x4 shortbox
luv2gomudn is on a distinguished road
Default Bucks kicks and backfires out tailpipes
Idles fine, and accelerates ok...just when holding steady speed, seems almost like getting crossfire from wires possibly...new cap rotor plugs pcv and air filter. Also done test to check bellypan gasket and get no suction at valve covers...check engine light flashes under hard acceleration, possibly extreme lean cuz it pings when it does that...
Old 01-30-2011, 09:49 PM
Possible bad crank sensor .
Old 01-31-2011, 11:13 AM
luv2gomudn's Avatar
Thanks, will check that...the codes I get are Oxygen sensor (lean) and idle air controller...
Old 01-31-2011, 11:29 AM
Rep:1885
A misfire caused by a lean condition? Sounds like a good possibility to me. Check this out if you think you have an inductive misfire. http://www.ramforumz.com/showthread.php?t=46269
Old 02-04-2011, 08:31 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
could be a stuck injector maybe? check to see if all those are working.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-06-2011, 11:14 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
O2 sensor. I had the exact same symptons as you are having now.
Old 02-17-2011, 07:33 PM
luv2gomudn's Avatar
Plugs, cap, rotor, wires helped alot. Still a little backfire when holding steady speed, but 100 per cent better. Also replaced O2 sensor and no check enging light on. Thanks for your help
