Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 01-31-2011, 10:48 AM
yancyk yancyk is offline
Vehicle: 2005 Ram 2500 4x4
Trim Level: lamamie
Color: blue and silver
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
yancyk is on a distinguished road
Default Left front caliper dragging??
Hi all, not sure if this is the right spot for this question. I have a 05 2500 4x4 and was driving the other day and noted a steering pull. Jumped out and checked things over, just visually. I found that the left front brakes where very hot and that is the side that i got the pull from. My front brakes are worn and i was going to replace them soon. My question is, is
it somewhat common for a brake caliper to bind up like this?? Do i need a new caliper when i replace the front pads and rotors?? Thanks everyone
Old 01-31-2011, 10:51 AM
Rep:1885
It's not too uncommon for this to happen if the rotors are worn and the pads are shot as well. The caliper pistons can get cocked in the bore and fail to retract. You could also have a brake hose that's collapsed internally. The easy way to tell is to apply the brakes, release them and then crack the bleeder screw on the caliper. If fluid shoots out under pressure, you have a collapsed hose. If it just trickles out, you have a caliper with a piston cocked in the bore. Sometimes the pistons can be pushed back with no ill effects but replacement is the preferred option.
Old 01-31-2011, 11:03 AM
Trim Level: lamamie
thanks for the info. i will check that.
Old 02-20-2011, 10:37 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i'd add to check the "slides/sliders" for the calipers. if they don't let the caliper return after releasing brakes, the pad will continue to make contact and get nice n toasty. not a pretty sight if left for too long.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 02-20-2011, 11:34 AM
I agree with both Randy and sdram03's statements . Go going gentlemen . Rep to both of ya 's .
Old 03-13-2011, 10:04 AM
clintho1 clintho1 is offline
Gender: Not Specified
Vehicle: 03' 5.9 1500
clintho1 is on a distinguished road
had the same problem but with the passenger side inside pad wearing the most it seems to be a bent vibration clip still keeping an eye on it ... any advice
Old 03-14-2011, 09:52 AM
Trim Level: lamamie
Here is a update. I have rebuilt the left front caliper. The dust boot had torn and let dirt get in and jam the piston. I replaced the piston and put new seals in. The caliper moves freely now. I was still having the brakes heating up and fading on the left side after about 20-30 min of city stop and go driving. So I then replaced the brake hose. I thought it was fixed until last night when it started to heat up again and cause a brake pull. Should i just replace both front calipers and hardware and the line on the other side?? What are the chances that it is a master cylinder?? This is getting annoying. THanks for any thoughts you guys might have.
Old 03-14-2011, 09:53 AM
Trim Level: lamamie
I have checked the caliper sliders and they slide easy and are not rusty.
Old 03-14-2011, 10:36 AM
Rep:1885
I advise replacing the caliper. I've seen this happen quite a few times in the past.
Old 03-14-2011, 10:51 AM
Trim Level: lamamie
I will order it up. Thanks Ram tech.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
Left front spkrs not working Dave Meyers Electrical 1 10-30-2010 07:58 PM
Front of truck not level - Left to Right NCBowhunter Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-11-2010 10:33 AM
Changing front left turn signal harley30041 Body & Interior 2 01-02-2010 04:15 PM
