Old 02-01-2011, 12:24 AM
Bodydoc2002's Avatar
Bodydoc2002 Bodydoc2002 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:138
Bodydoc2002 will become famous soon enoughBodydoc2002 will become famous soon enough
Default Exhaust Question ...Single vs Dual
Is there a "Real" Benefit to a dual vs Single exhaust system? I'm talking outside of "looks" and "Sound" I mean performance...
2009 2WD Ram 1500. 7 inch CST Lift. 35 inch Mickey Thompson BAJA ATV. 20 inch ATX Artillery wheels. TOFF Spray in Bed liner. N-Fab 6 step Nerf Bars. BushWacker Pocket/Painted Fender Flairs. Diablosport Predator. K&N CAI 77 Series. 180 Thermostat. LED Tailgate lights.
Old 02-01-2011, 12:34 AM
Rep:1625
From Auto Anything:
"If your vehicle has a stock single exhaust system (if there is only one head pipe running from your engine back to the muffler) and you install a dual exiting exhaust system, you will get the same intense boosts in horsepower and torque as with the single exiting exhaust.
The major difference between single and dual exiting exhaust systems is the number of tailpipes: the single has one tailpipe, and the dual has two. While the tailpipes augment your vehicle's style and attitude, they do not improve the performance of the exhaust."
Old 02-04-2011, 07:07 PM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
I think the most performance comes from a "true dual" setup. 2 head pipes & 2 mufflers.
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 02-04-2011, 07:35 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Per Magnaflow regarding cat-backs:
Question: Does a dual cat-back exhaust system perform better than a single?
Answer: In most cases a single exhaust will give you better torque and horsepower. The exception would be a heavily modified engine.
Per Magnaflow FAQ's /pipe size:
Use the guide below when calculating pipe size for custom exhaust work. Keep in mind that the goal is to improve exhaust flow. In most cases, just changing the restrictive OEM muffler and replacing it with the same size straight-through, Wide Open Performance MagnaFlow muffler will do the job.
To reduce additional backpressure, the OEM exhaust tubing can be replaced with mandrel-bent tubing of the same size or one size up from the OEM. As a general rule, you can enlarge the pipe diameter of your OEM exhaust system by 1/4 to 1/2-inch to increase your horsepower. However, any additional increase in pipe diameter is likely to decrease your performance; specifically, low end torque.
ENGINE SIZE HORSEPOWER MUFFLER INLET/OUTLET Single Exhaust Dual Exhaust
150-200 CID 100 to 150......................................2" to 2-1/4"............2"
200-250 CID 100 to 200......................................2-1/4" to 2-1/2"......2" to 2-1/4"
250-300 CID 150 to 250......................................2-1/2" to 3"............2" to 2-1/2"
300-350 CID 200 to 350......................................2-1/2" to 3"............2-1/4" to 2-1/2"
350-400 CID 250 to 550......................................3" to 4"..................2-1/2" to 3"
Use as a general guide for engine size and performance
SOOOOOOOOOOOOOOOOOOO, Are duals a necessity????? Not if you have the right sized pipe for your application.
Old 02-04-2011, 07:49 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I agree, I went with a new, better flowing Y-pipe from the cats back into 3" split out of the muffler to 2 1/4 on each side. Both the Y-pipe and muffler came from Magnaflow. Check it out. Video and pics.
http://ramforumz.com/showthread.php?t=71908
WTB - Stock 09+ Sport or R/T dual exhaust muffler jmr Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 09-30-2010 10:26 AM
Exhaust for a 06 single cab 8ft bed? LSxFBODYgen3 Exhaust 2 08-06-2010 10:58 PM
Factory dual exhaust question wickedpissahtruck Exhaust 5 07-26-2010 01:56 AM
Single out or dual out? bones64 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 06-14-2010 09:07 PM
general exhaust question H22A1 2010 Dodge Ram Forum 5 05-27-2010 11:15 PM
