Old 02-01-2011, 08:13 AM
xtree xtree is offline
Vehicle: 1997 Dogde Ram 1500 4x4
Trim Level: I don't know
xtree is on a distinguished road
Default Cold Start and Idling issues
My son has a '97 Ram 1500 4x4 with a 5.9L. The truck runs fine in warm weather. We live the NE and since the weather has turned cold the truck is very hard to start. Once warmed up it runs well but can die when you come off the accelerator while driving along.
I searched the forum and found a similar post which indicated a bad IAC. Is this a common issue, and is there a published test procedure? Thanks for any advice..
Old 02-01-2011, 09:24 AM
Rep:1845
Try removing and cleaning the throttle body and IAC passages before you drop money on a new IAC. http://www.ramforumz.com/showthread.php?t=46454
Old 02-01-2011, 09:59 AM
Default added information
I pulled the codes and have 2 which could cause this I think.
1) P0122 - Throttle Position Sensor (G69): Signal too Low
2) P0117 - Engine Coolant Temp. Sensor (G62): Signal too Low
I cleared the codes and will monitor.. Any other troubleshooting tips or pointers to diag routines are greatly appreciated
Old 02-01-2011, 10:01 AM
Default Thanks for the tip
Will give it a try when I find the keys I lost this AM. Boy some days it's not worth getting out of bed.
Old 02-01-2011, 10:17 AM
Rep:1845
Either of those codes could have an impact on performance. When you pull the throttle body for cleaning, inspect the terminals in the TPS sensor plug to make sure there's no corrosion or spread terminals.
Old 02-03-2011, 05:51 AM
My son took the truck out after I cleared the codes once we found the keys (wife accidentally grabbed them on the way to work). Sure enough the check engine light came on. Pulled the codes again and this time only the P0117 was posted. I replaced the coolant temp sensor and that did the trick. Truck started right up this AM.
Last item on the list is the starter is about to go. Have to turn the key a few times before it will spin.. I haven't looked to closely at the starter but was wondering if it is a straight forward pull??
Old 02-03-2011, 09:34 AM
Rep:1845
Yeah, and if you want to save a few bucks, have a local rebuilder put in a set of fresh contacts and a new plunger. That's about all the ever goes wrong with the Nippondenso style starter you have.
Old 02-05-2011, 08:39 AM
Great, thanks. Will probably pull it next week and bring it to a rebuilder. I have one a few miles from my house..
Old 02-14-2011, 11:49 AM
Local re-builder had one in stock. The push pull was straight forward. Just needed a long extension to get past the front diff and drive shaft. Truck starts and runs like a champ now. Thanks for the help.
Old 02-14-2011, 12:28 PM
Rep:1845
Yeah, it's a pretty easy swap. Glad you got it taken care of.
2003 4.7 idling high! Thetolleyman 4.7L PowerTech V8 Specific Topics 7 11-20-2010 05:13 PM
2001 not idling right got hemi 5.9L V8 Specific Topics 3 10-20-2010 11:21 AM
98 Ram with issues Adam208 5.2L V8 Specific Topics 6 10-13-2010 04:02 PM
A/C compressor cycling rapidly, still cold, but not at idle scooper77515 Heating & Cooling 1 04-06-2010 09:32 PM
