Old 02-01-2011, 11:07 AM
nygiantfan622 nygiantfan622 is offline
Vehicle: 2008 Ram 1500 QC Big Horn
nygiantfan622 is on a distinguished road
Question illumination lights....difficult to change?
:attn: Well I've been looking to change out the illumination lights for the dash, door controls 4x4 knob as well as the headlight switch, and hvac controls and so on, I have done some research and found a video on youtube and found where I can get replacements(superbrightleds.com). My main concern is any major issue or concerns to be worried about. Anyone that has done this and can shed some light on this would be helpful thx!
Old 02-01-2011, 11:13 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Welcome to the forum, I'm confident you came to the right forum for answers!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 02-01-2011, 11:16 AM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
It's actually very easy, just take out a couple screws, pull off the dash,twist the old bulbs out with a screwdriver/pliers, twist the new ones in, and put the dash back into place. There's a youtube video where the guy does it on an 08 that's very helpful.
2008 Dodge Ram
35% Tint, Flowmaster 40, Custom painted interior, Painted grill emblem, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
Old 02-01-2011, 11:25 AM
I have watched that video a few time and seems pretty easy and shouldnt take long to do, my main concern is with some of them it seems to be that you have to get just a 3mm LED with a resistor (470ohm) and sodder the back to the board but even that seems easy given you don't have to worry about the polarity......given the Price of the LEDs its a nice cheap face lift to the crappy green! Thanks a lot
Old 02-01-2011, 11:52 AM
mrboots's Avatar
Color: Inferno Red
Rep:137
Yeah, if you want to do the headlight switch, 4wd switch, auto rear window ect there's some soldering required. I haven't done any of those yet but keep meaning to get around to it. If any bulbs don't work the first time just flip them around to reverse the polarity and you should be good to go.
2008 Dodge Ram
Old 02-01-2011, 11:55 AM
mrboots's Avatar
Color: Inferno Red
Rep:137
Oh I almost forgot, down there on the HVAC controls if you use blue bulbs it wont shine through the red for the heat portion, I ended up using a blue bulb on each side and a white one in the middle. It looks a tiny bit off until if gets dark out if you know it's there, but once it does nobody will really notice.
2008 Dodge Ram
Old 02-01-2011, 01:18 PM
What brightness did you go with I notice that they have a 2 lumin and a 6 lumin, thanks for the pic looks good I'm going with red for mine.
Old 02-01-2011, 02:23 PM
mrboots's Avatar
Color: Inferno Red
Rep:137
In that pic those are the 2 lumen, I've since changed to the 6 all around and like it a lot better.
I'm not sure how red is gonna come out..there is a blue film covering everything back there that is kinda stuck to the inside of the gauges. The OEM bulbs are a yellow-ish color, and when they shine through the blue film that's what gives it the green color.
I'd def do a test first, I wonder if it may come out purple? Though, I've heard of some people using a q-tip and rubbing alcohol to remove the film, that should be ok but it'll just be a bit more work.
2008 Dodge Ram
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 02:00 AM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
Part numbers for Lights? DarkRam01 Custom Dodge Ram Interior and Exterior Lighting 4 03-01-2010 11:50 PM
another trailer lights problem scbachman Newbie Checkin! 3 06-09-2009 08:55 PM
