Old 02-01-2011, 02:05 PM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Default Performance Chip?
Looking for performance chip for my 2011 6.7L turbo diesel.
Suggestions please!
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Old 02-01-2011, 02:20 PM
I used one of the Banks Six Gun systems on my prior diesel and was impressed!
Old 02-01-2011, 07:32 PM
ScatPak07's Avatar
Rep:970
Take a look at Rollin Smoke for the tuners available for your truck. Look at the H&S XRT and Mini Max tuners they seems to be a good one for the cummins. You should also take a look at the PPE tuner I have heard great things as well.
If you are adding a tuner you should look at removing your DPF. Only thing is you will have to wait until your warranty is up since it will void it. The DPF really restricts the trucks exhaust flow and removing it will be a great idea. If you dont mind doing it then you will be pretty damn happy. If you see the DPF it looks like a friggen bomb or something, its pretty funny. If you do remove it you will need to install the tuner or else you will have a shitty smelling truck. The diesel exhaust wont exit properly so the tune burns the diesel better so the exit isn't that important.
Does your truck run the diesel exhaust fluid?
http://www.rollinsmokediesel.com/cat...rsmodules2.cfm
Take a look at Diablo Sports Extreme Power Puck for the Cummins as well. You can use it along side a Predator so you will have 2 tuner for the truck and you can add around 200hp and 400ft/lbs!! I WANT A DIESEL!!! hahah
http://www.diablosport.com/index.php...isplay&pid=136
Old 02-03-2011, 09:10 PM
Rep:20
Anyone with experience of DIESEL TUNES PERFORMANCE DIESEL CHIPS?
knsram
pcd performance stage 1 chip ? question nitro1965 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 01-08-2012 11:43 PM
Performance Chip for 06' 1500 Mega Cab megacabmatt Dodge Ram General Discussion 1 11-01-2010 05:22 PM
Slr performance chip REEROO Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 10-05-2010 09:58 AM
Performance chip, someone help me swords hemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 11 01-04-2010 09:23 PM
Performance Chip? Robsfare Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 4 12-01-2009 08:57 PM
