Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 02-02-2011, 07:06 PM
2001RAMSPORT's Avatar
2001RAMSPORT 2001RAMSPORT is offline
Vehicle: 2004 Dodge Ram 4X4 HEMI
Trim Level: Sport-Offroad
Color: Atlantic Blue
2001RAMSPORT is on a distinguished road
Default Robbing MPG?
Just a quick question.
Is it true that leaving the A/C and Heat on in the truck steals some mpg?
Thanks
Old 02-02-2011, 07:09 PM
A/C yes as you have to drive the A/C compressor off your accessory drive belt and it creates resistance, requiring more power to turn the engine.
Old 02-02-2011, 07:12 PM
Trim Level: sport
Color: green
Rep:643
"back in the day", many would say a/c used up 1 to 2 mpg. then tests wre done and it was concluded that driving with windows down used more mpg do to drag on the car. never read a study, this all here say from "old motor heads from the sixties. i am sure turning the compressor uses a little mpg. i don't see how heat would.
Old 02-02-2011, 07:14 PM
Thanks so if i run the a/c it is the same as taking the compressor off?
Old 02-02-2011, 07:33 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Heat is free energy given off by the motor, no power robbed at all, UNLESS you are running the defrost mode since that will kick on the A/C compressor. A/C will rob some power as you are adding more drag to the motor by running the compressor, but in 100* heat it's worth it. Remember to turn off your A/C when you turn of your engine, it's not good to leave it on ALL the time.
www.beatcraigslist.com - for posting dangers & secrets
Old 02-02-2011, 08:02 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
In my experience, driving with the AC on does not negate fuel mileage much, if at all. It certainly does not hurt MPG enough that I think I should go without it! I like to be comfortable while I drive, and darn the circumstances of lost MPG!
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-02-2011, 11:44 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
i never use it in the city i always go windows down I have heard it does hurt mpg however the drag created on the highway would for sure be enough to give the same affect i would think. I always run it on the highway tho on hot days cause windows down is just too windy for this guy.
Old 07-07-2011, 10:06 AM
Actually Mythbusters did a test and driving with the windows down is more fuel efficient.
Old 07-07-2011, 01:42 PM
And who wants to do that ^^^^ on a HOT summer day???
Old 07-07-2011, 02:49 PM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Send a message via Skype™ to dwadestrick
Not me. High today 90 F with heat index of 95 F and humidity of 70% and no rain.
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
MPG / Wheel Size jokkling Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 41 01-09-2013 05:26 PM
MPG Convresion help needed gregster 2010 Dodge Ram Forum 13 09-19-2011 01:20 AM
My MPG ShotGunWillie 2009 Dodge Ram Forum 12 08-14-2010 01:35 AM
Installed K & N intake, Getting worse MPG...HELP! 20ram08 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 12 07-21-2010 11:20 PM
Any real world results? (MPG gain with tuner?) HoustonHemi Dodge Ram MPG Zone 12 06-05-2010 01:00 AM
