V 10 gear oil - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-02-2011, 11:03 PM
mitsocruiser's Avatar
mitsocruiser mitsocruiser is offline
Vehicle: 98 dodge ram
Trim Level: 2500 sport
mitsocruiser is on a distinguished road
Default V 10 gear oil
Changing out fluids this weekend was wondering if royal purple gear oil will work for my 5 speed tranny I use royal in all my other vehicles and builds. Didn't know if this motor our tranny require special fluids I appreciate any help new to v10 but hit me up if you have a 2.0 built a few mitsubishi's
Old 02-03-2011, 12:19 AM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Are you just using Royal purple because you use it in other vehicles you own? Have you looked into other synthetics?
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-03-2011, 08:16 PM
I've just had good results out of royal in my 2.0L vehicles just wondering if v10 require specific weight or brand oil and other fluids
Old 02-10-2011, 08:14 PM
Thanks to my good buddies at pepboys I can answer my own question it only requires 75X90 gear oil doesn't matter what brand
Old 02-14-2011, 07:16 PM
95dodgeV10's Avatar
95dodgeV10 95dodgeV10 is offline
Vehicle: 1995 dodge ram 2500
Trim Level: Laramie SLT
Rep:24
95dodgeV10 is on a distinguished road
i switched my v10 totally over to royal purple but i have auto tranny, i usually run 15w40 in the summer and switch to 10w40 in the winter for easier cold starts. 200000 miles and run great oil comes out a nice light brown every 5000 miles or so
Old 03-14-2011, 12:31 AM
sikedude sikedude is offline
Vehicle: 1997 Dodge Ram 2500
Trim Level: SLT Laramie
Color: Green
sikedude is on a distinguished road
New Venture specifically notes to use Castrol Syntorq 75-90 or equivalent in the NV4500. The 4500's have carbon fiber gears in them that conventional oil can damage. As long as its a GL4+ rated synthetic you should be fine.
Old 03-30-2011, 02:36 AM
debora450 debora450 is offline
Trim Level: 1500
debora450 is on a distinguished road
All factory parameters are adjustable not just “powered up” so that your car will perform and drive “better than factory”.
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 08:45 AM
1st and 2nd gear WHINE JakeRam02 4.7L PowerTech V8 Specific Topics 2 09-21-2010 11:02 AM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 12:02 PM
rear diff philjohn 4.7L PowerTech V8 Specific Topics 26 06-27-2010 09:09 PM
How to figure out gear ratio ramit04 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 7 11-13-2009 05:36 PM
