Old 02-26-2011, 10:13 PM
Ziggy's Avatar
Ziggy Ziggy is offline
Vehicle: 2006 Ram 2500
Color: Grey
Ziggy is on a distinguished road
If you get the tires balanced check there position on the rim first. Every new tire has a dot about a 1/2 inch above the ribbon. Make sure the tires where mounted with that DOT aligned with your air nozzle. Then the balance should be perfect. A lot of dealerships just throw tires on with out lining them up. It can case problems right away on big tires and lifted trucks..
Hope this helps...
Fortunate Son !!!!
Old 02-27-2011, 06:49 AM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Hope this helps...
I don't agree......The Dot has nothing to do with the balance of the tire. It is only a referance point to be used when the tire is removed from the rim and then replaced.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Vibration at 60 MPH and cupped tires davidreed 5.7L (345 cu in) HEMI V8 Specific Topics 14 06-13-2013 09:13 AM
Vibration around 2500 rpms lucidanomaly Newbie Checkin! 14 04-25-2012 01:15 AM
Vibration in the Rear ubbulls32 Suspension 4 09-01-2010 09:36 AM
1999 Dodge Ram 2500 4x4 rear driveline vibration Wilkinson Mike Newbie Checkin! 4 07-08-2009 04:37 PM
'07 1500 4X4 Vibration rottyrott Suspension 7 05-25-2009 11:51 AM
