Old 02-03-2011, 02:26 AM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Default Factory Sirius ?
I have a 2008 with factory Sirius and single CD stereo. I am looking at getting aftermarket double-din DVD player that is Sirius ready and was wondering if anyone knows if it is possible to use the factory installed Sirius antenna with the new head unit as I don't want to have to use a magnetic one or something when I already have a perfectly good one. I have read that if you unplug the antenna wire from the receiver and remove the plastic piece on the end it will expose the metal plug and it will plug into a Sirius Doc but I don't believe that's the same style plug-in that would be on back of a head unit. Anyone tried this ?
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 02-03-2011, 07:21 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
A sirius "ready" radio will still require the Sirius "receiver"...but you should still be able to use the stock antenna as the connections are the same on all the sirius radios
Old 02-03-2011, 07:41 PM
sk8noregon's Avatar
Rep:637
So you're saying I could remove the factory receiver and buy one that's compatible with the new head unit and be good to go ? Thanks for the response.
Old 02-03-2011, 07:54 PM
Rkeytek's Avatar
Rep:210
It seems like the antenna connection on the receivers all have that plastic piece... see the pic
So at that you just have to make sure the head unit and receiver are compatible.
Old 02-09-2011, 12:20 PM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
I was told by a salesman at futureshop that I could use the factory antenna with an aftermarket dvd player, just get the sirius reciever for the brand of dvd player you`re getting. I called sirius and once installed all you have to do is call them and get your subscription transfered over to the new receiver, all you need is the new serial number.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Sirius antenna/head location HEMIBLUDA Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 06-03-2010 10:25 AM
SIRIUS Satellite Radio GTyankee Movies And Entertainment 7 03-24-2010 10:02 AM
Sirius Antenna rjs2005 Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 02-11-2010 07:23 PM
Sirius Radio - Non Transferrable!?!?! colingibb Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 06-26-2009 10:19 PM
