Remote starter quits in cold weather - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-03-2011, 06:44 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Default Remote starter quits in cold weather
On mornings when its exceptionaly cold I and I try to use the remote starter , the truck will turn over and start for about a second and then shut off and will not restart until I put the key in and turn it over. Was wondering if anyone else has had this issue and possibly found a fix through the dealership. The number one time I want to use the remote is when its really cold , so it seems silly that it wont work right in the cold
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 02-03-2011, 07:05 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
All I have noticed is the remote start range is less when it's really cold, was 3 degrees this morning, but it always starts. Maybe the dealer can help...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 02-03-2011, 07:14 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Were there any messages on the EVIC when it failed? Low fuel or one of the microswitches (hood) not properly contacting?
Old 02-03-2011, 07:15 PM
lefty33's Avatar
lefty33 lefty33 is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Crew
Trim Level: Sport Premium
lefty33 is on a distinguished road
Have you checked the fuel level? If it's too low, the truck will start and then shut off...the nanny doesn't want you running out of fuel while it's sitting there idling.
Old 02-03-2011, 07:21 PM
FDBDW's Avatar
Rep:172
Nope fuel and hood were fine, ive had that happen before. My dad has the same truck and he had it happen to him also.
Old 02-03-2011, 07:23 PM
NWTJetboater's Avatar
NWTJetboater NWTJetboater is offline
Trim Level: Fully Loaded
NWTJetboater is on a distinguished road
Mine wont start at all when it is too low on fuel.
Mine doesnt always work either...sometimes I have to press lock-unlock then start..weird, but so far works right down to -42
"If you ain't hitting bottom, you ain't jetboatin !"
Old 02-03-2011, 07:24 PM
dmtonka dmtonka is offline
Vehicle: 2007 dodge ram
Trim Level: 1500 hemi 5.7
dmtonka is on a distinguished road
I had same problem is your check engine light on that will stop it. Did you check the pin switch underhood also
Old 02-03-2011, 07:37 PM
FDBDW's Avatar
Rep:172
If it was a door or hood it would not turn over at all, Ive had that happen before. No check engine light, not low on fuel. It turns over, starts for a second then dies when I go out and put the key in , it starts and stays running and nothing on the evic. Only time its happen is the last two mornings -20 deg, happen to me and my dad ( he has a truck the same year as mine) so its not an individual issue with just my truck
Old 02-03-2011, 07:47 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
i had a similar problem in my 05 if it was too cold or i had the heater fan up too high it was drawing too much current and wouldn't start. it was an after market unit that my buddy 's shop installed he just lengthened the amount of time that the the starter would run
Old 02-03-2011, 07:54 PM
Check with the dealer . They may have a TSB on it .
Truck cranks and cuts off in cold weather ramblinyota 5.2L V8 Specific Topics 5 02-06-2011 10:47 AM
Stalling in cold weather. Air Idle Valve? Todd F 5.9L V8 Specific Topics 3 12-06-2010 10:12 PM
Remote car starter DYNO Electrical 2 11-11-2010 03:46 PM
Help from my cold weather friends! BlueJet Off Topic Discussion 18 12-07-2009 01:50 PM
Diesel Engines and Cold Weather 2nd Ram LD RAM - General Discussion 3 10-18-2009 08:33 PM
