Old 02-03-2011, 07:01 PM
wedgeheaded's Avatar
wedgeheaded wedgeheaded is offline
Vehicle: 06 1500 QC 4x4
Rep:111
wedgeheaded will become famous soon enoughwedgeheaded will become famous soon enough
Default explain this, 315 70 17 measures 33"
I walked out to the credit union this afternoon and my buddy's CTD was sitting there with new 315 70 17 BFG A/T KOs. I had my tape in my pocket so I measured across the tire. It cam up just over 33". My other buddy had his 75 3/4 ton sitting there with 35s, I measured them, 33". I can understand the 35s as they are nearly shot and tread counts. But those BFGs are nearly new. They should measure 34.5 per BFG specs. I measured across too, not from the ground up. I don't understand.
Old 02-03-2011, 07:03 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
No idea!!!!! Sorry!
Old 02-03-2011, 07:11 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Pressure in the tire was not high enough? So the tire was bulging at the bottom causing it to seem shorter. I dont know just a guess.
Old 02-03-2011, 08:31 PM
I'd have to agree , maybe the tire pressures were low . I'm running 315's and they are definitely taller than 33's . My truck came from the factory with 33's .
Old 02-03-2011, 09:14 PM
ScatPak07's Avatar
Rep:970
Yea tires do that haha. I have the same thing with mine in 35". I think they measure like 33.5" or 34". Like mentioned above the tire is bulged at the bottom due to the weight. If you measure it before install I am sure it will be very close to the specs
Old 02-03-2011, 10:57 PM
My 285/75R's are listed as 34.7" tires at the recommended inflation pressure of 45 pounds. I'm gonna have to go out and measure them!
Old 02-04-2011, 10:09 AM
Rep:111
I didn't measure from the ground to the top of the tire. I measured across the tire. I'm going to measure it again today if he's here. I may be a victom of bi-focal glasses. All I know is it threw me for a loop.
Old 02-04-2011, 05:16 PM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
No, your measuring correct! You said his tires are 315/70 not 315/75.... hence they would be 33's not 35's. The first number isn't the height its the width, and the second number is a percent of the width is the sidewall height or something like that. Hope this helps.
Old 02-04-2011, 05:31 PM
Rep:1845
Right on the money!
Old 02-05-2011, 07:35 AM
Rep:111
You are right. Now, look up the spec for that tire at BFGs site. It says a 315 70 17 is 34.5" tall. I can see loosing an inch or so between new to worn out, but these tires are fairly new.
Explain how MDS operates. DBryant MDS 39 10-09-2013 06:18 PM
can anyone explain this to me? rancherman Photography/Videography 1 09-22-2010 08:20 PM
Can anyone explain to me why... strang3majik Off Topic Discussion 1 09-13-2010 02:06 AM
Chrysler fan, explain the hate.. ericautopart Other Vehicle Discussion 17 07-25-2010 09:28 AM
33" tires LandRam1500 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 04-29-2009 04:34 PM
