Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-04-2011, 01:04 AM
TEAMTITAN70 TEAMTITAN70 is offline
Vehicle: 2004 dodge ram 5.7 hemi 4x4
Color: red
TEAMTITAN70 is on a distinguished road
Default egr valve blocked off why???
just took my egr valve off my 04 ram 1500 hemi i had already bought a new one but i dont know if i should put it on or take it back. when i took off the old one someone had put a solid plate between it and the front of the head does anyone know why someone would do this does it make more power or something since it is blocked off.thanks
Old 02-04-2011, 09:08 AM
Resident Technician
Rep:1909
It won't make enough of a difference that it will matter unless you're kicking and clawing for every ounce of HP you can get. Put the old valve back on and drive the truck to make sure the MIL stays off.
Old 02-04-2011, 03:53 PM
Color: red
what is the mil? i put the new one on last night and drove it down the road im happy i put the new one on it helped the truck felt like it added another 50hp.no more ruff idle no more hesitation all i can say is wow for now.i also unhooked the battery so maybe that had something to deal with it. check engine light is still on and it still falls to 400 rpm when i stop and stalls
Old 02-04-2011, 04:05 PM
Resident Technician
Rep:1909
The MIL is the Malfunction Indicator Lamp. Unhooking the battery won't clear out the code, so get it rescanned and if none of the codes are active, clear them out. The stalling is likely from a dirty throttle body. Here's how to clean it - http://www.ramforumz.com/showthread.php?t=46764
Old 02-04-2011, 04:17 PM
Color: red
ok thanks. i took the intake off last week and cleaned everything got all that built up black stuff out of all the lines and cleaned the filter box got it all looking like new again and since then thats when my stalling has started.i noticed a sensor in the front of the intake dont know what it is think that could be it. the rubber gasket that goes on at the body and intake was still good even had it off again last night and made sure.
Old 02-04-2011, 04:54 PM
Resident Technician
Rep:1909
The sensor you're talking about is the IAT (Intake Air Temp) sensor and it wouldn't case a stalling problem. Get the PCM scanned again and we can go from there.
Old 02-04-2011, 06:28 PM
Color: red
will do i should have time to do it and post tomorrow thanks
Old 02-12-2011, 04:58 AM
Color: red
ok i scanned it got these codes po174 system lean bank 2 next code was po157 02 circuit low voltage bank 2 sensor 2 truck is so bad i dont know what else to do also had code po430 the truck idles at 600 rpm every time i stop it drops to about 400rpm and stalls but if i throw it in neutral before i come to a stop it is fine.or if i can stop and let off the brake when the rpm starts to fall it will jump back up and start surging ???????im thinking about hacking off the converters but if i do that what do i do about the 02 sensors that are behind them we dont have a smog test where i live and the thing is drinking gas bad we are talking about 1/4 tank every 40 miles. thanks
Old 02-15-2011, 03:59 AM
05akram 05akram is offline
Vehicle: 2005 qc 1500
05akram is on a distinguished road
I had similar problems. I dont remember the code but the left engine bank lean is the 02 sensor. Hope this helps.
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 11:17 PM
Valve Cover Leaking nauticstar 2110 Cummins Diesel Specific Topics 6 02-01-2011 09:35 PM
valve covers? bfinley Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 12-18-2010 01:47 PM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
