Old 02-05-2011, 11:21 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
It is my understanding that the air we breathe, and is in your tires, is about 78% nitrogen, 21% oxygen and 1% other gasses.
Like RamTech said, a lot to pay to replace about 20% of what is in your tires and I can't air them at home.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 09-04-2011, 02:04 PM
WhenInDoubt101 WhenInDoubt101 is offline
Vehicle: 2011 Ram Bighorn 4X4
WhenInDoubt101 is on a distinguished road
I was pleasantly surprised to see Nit came with the truck when I purchased it. I'm a firm believer in Nit, my last set of tires on the old retired Ford I got 77,000 miles out of the tires and never had to check the pressure. The tire dealership always checked tire pressure when I had them rotated. One of these days I'm going to have Nit put in my trailer tires too, to me it's well worth the money, but of course I put 45,000 a year on my trucks and have enough things to service more than I want.
Just Me.
Old 09-05-2011, 10:11 PM
mike49 mike49 is offline
Vehicle: 2009 Dodge Ram 1500
Color: tan
mike49 is on a distinguished road
Originally Posted by heffs03mach1 View Post
for the guy asking about nitrogen. my understanding of it all is that nitrogen does not compress or expand like air and is made up of bigger molecules so it doesnt leak out thru the tire. not a rocket scientist here but thats the gist of it i think. someone on here a lot smarter may be able to explain it better. it is expensive to have it done but they say you get better mpg, longer tire life, more even wear etc. i dont know that there really is a big enough difference for the cost.
It's pretty much B.S. - the only possible benefit I can see is eliminating the oxygen from inside the tires may retard aging/degradation of the rubber, and less moisture content will delay rust of the wheels. For a good explanation: http://www.tirerack.com/tires/tirete...jsp?techid=191
ps - normal air is 78% Nitrogen http://en.wikipedia.org/wiki/Atmosphere_of_Earth
Bottom line - not worth the money as long as you check your tire pressure regularly
Old 09-07-2011, 10:02 PM
FireWire's Avatar
FireWire FireWire is offline
Vehicle: 2011 Dodge Ram
Rep:12
FireWire is on a distinguished road
My 2011 came with nitrogen in the tires. I assume it came from the factory that way.
I doubt that the dealer did it.
Old 09-09-2011, 04:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The module is programmed to alert at a preset pressure. Unfortunately there is no calibration procedure to set the pressure transmitted by the sensors.
My superchips flashpaq allows me to adjust the TPMS, not sure if you can adjust it to any setting, but I think you can adjust it at least on or off. They have the option for people who do rock crawling and stuff like this.
Sean
Old 09-09-2011, 06:09 PM
Rep:2616
When i bought new tires & wheels, i didn't want to disassemble the chrome clads w/ the stock tires, i spent a bit of money & bought new TPMS sensors too
Now i can be on a hill on a hot summer day & the check tire light comes on, tire pressures are pressurized correctly & each time i had been on the road for quite some time
TPMS sensors were checked out at Discount Tire where i bought them, nothing found. I also have a truckers tire gauge with me
Old 09-09-2011, 07:12 PM
GoatFarmer's Avatar
GoatFarmer GoatFarmer is offline
Rep:13
GoatFarmer is on a distinguished road
One of the big reasons they put nitrogen in your tires straight out of the factory is the moisture issue. Air is made up of Oxygen, Nitrogen, and other elements like Hydrogen. Hydrogen, and Oxygen make water... Water F's with your TPMS... They don't want you bringing your truck back to the stealership once a week complaining that the TPMS doesn't work, so they go with Nitrogen. Nitrogen has some benefits (not enough to pay that much extra IMHO) but pretty well any car with TPMS valve stems will come straight from the factory with it in the tires.
Geoff
Work Truck : Silver 01 Ram 1500 4x4 Toy : Mineral Gray 2010 Ram 1500 4x4
Old 09-10-2011, 04:35 PM
mtbiker033's Avatar
mtbiker033 mtbiker033 is offline
Rep:25
mtbiker033 is on a distinguished road
at my dealership they have nitrofil and I haven't had to do anything to them for over a year. the pressure is always constant no matter what the weather is. It only cost $39.95 for lifetime of the vehicle.
2010 Dodge Ram 1500 Quad Cab // K&N Drop in // Tint (20% rear / 35% front)
Tire Pressure GPSHSLAX Dodge Ram General Discussion 33 10-22-2009 11:12 PM
Tire pressure sensor Fast Willy Dodge Ram General Discussion 2 10-19-2009 04:49 PM
Low tire pressure indicator question imnxnyr Dodge Ram General Discussion 14 10-06-2009 11:49 PM
Nitto 285/50 R20 tire pressure texasf Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 09-16-2009 07:31 PM
Tire pressure for 37in ? Marcelo Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 03-13-2009 10:11 PM
