Old 02-04-2011, 10:02 AM
warwickram's Avatar
warwickram warwickram is offline
Vehicle: 09 ram 1500
Trim Level: laramie
Rep:38
warwickram is on a distinguished road
Default what size nittos
what size nittos can i use on a 07 1500 stock will 275/65/20 fit ok
Old 02-04-2011, 11:06 AM
Resident Technician
Rep:1909
A friend of mine just ordered that exact same set for his, so we'll see sometime next week if he has any clearance issues. If he does, it can easily be fixed because he has the torsion bar setup and I can raise the front a bit if needed. The tire is 26mm (a touch over 1 inch) bigger in diameter so I don't think we'll have a problem.
Old 02-04-2011, 11:12 AM
warwickram's Avatar
Trim Level: laramie
Rep:38
thanks do you know how much he paid i found them on line for like 240 each
Old 02-04-2011, 11:28 AM
That size should be good from a height standpoint. Not sure if the 275 will rub at steering lock inside the wheelwell or not.
Old 02-04-2011, 01:31 PM
warwickram's Avatar
Trim Level: laramie
Rep:38
i have 275/ 60 now no rubbing do you think that extra height will make a differences
Old 02-05-2011, 12:24 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Stock tires on mine are 275/60/20. They are 33". A 275/65/20 are 34". I was told to get a leveling kit to fit these. They may be too big for the lower fronts on Rams.
Old 02-05-2011, 12:42 PM
warwickram's Avatar
Trim Level: laramie
Rep:38
well i just ordered the nittos 275/65/20 if they rub i guess i will be getting a leveling kit or the blistins
What is the max tire size that will fit on rams wester399 Dodge Ram General Discussion 4 10-05-2010 12:33 PM
CAT/Y-Pipe inlet size GPSHSLAX Exhaust 5 09-06-2010 02:08 PM
So....What Size is the Right Size? HoltFF1074 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 0 08-17-2010 03:03 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-22-2010 12:37 AM
What size to go with? RarebreedRam Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-11-2010 06:30 PM
