Old 02-04-2011, 12:22 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
Default Needing a question answered from smarter people than myself
Im dumb and need help
Ok, well right now I have a 6" BDS lift with nitto trail grapplers (35x12.5x20) on my stock 2010 20" rims. I have a 1/4" spacer in there at the moment to allow just enough room for the swing arm. I am looking at buying new rims specifically Rockstar XD that will push the tires out.
My question is can someone please explain backspacing/offset to me, so when i do go get these rims I will know something about what i am actually looking at and asking the dealer for.
thanks in advance
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 02-04-2011, 12:28 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Maybe this will help..
How to Measure Wheel BackSpace
Items required to measure wheel backspace: Tape measure Straight edge Wheel w/o tire (preferred)
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
Measuring Wheel Offset
To calculate offset you'll need the following measurements:
Wheel backspace Wheel Width Wheel Center line (outboard flange to inboard flange measurement / 2) Subtract:
Wheel center line from Wheel backspace to get offset. If backspace is less than the wheel centerline the offset is negative If backspace is greater than the wheel centerline the offset is positive Tip:
To convert from inches to mm multiply by 25.4 To convert from mm to inches divide by 25.4
Backspace to Offset Conversion Chart The table on the right is q quick reference for finding offset, pick the rim width and follow the row over to the backspace of your wheel.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 02-04-2011, 12:30 PM
BLKSVT's Avatar
Rep:222
or this....
Backspace and offset are two ways of describing where the wheel sits in relationship to the hub. As such, there is a relationship between the two making - it possible to convert from one to the other.
Backspacing is the easiest to understand. It is simply the distance from the back of the mounting pad to the back lip of the wheel. It is measured by laying the wheel on its face, placing a straight edge across the wheel, and then measuring down to mounting face. The higher this measurement the more the wheel is pushed inboard towards the car’s centerline, as shown in the illustration above.
Offset is the distance from the mounting surface to the centerline of the wheel, expressed in millimeters. Positive offset means that the wheels are pushed inboard towards the centerline of the car like a car with front wheel drive. Negative means that the wheels are moved outboard towards the fenders, widening the track.
TO CONVERT OFFSET TO BACKSPACING:
For positive offset wheels: (Wheel Width +1)/2 + (offset * .03937)
For negative offset wheels: (Wheel Width +1)/2 - (offset * .03937)
TO CONVERT BACKSPACING TO OFFSET:
Backspacing – (Wheel Width + 1)/2 * 25.4 = offset
Round this result to the nearest milimeter. If the answer is a negative number the wheel has negative offset, if positive then a positive offset.
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
well first of all that is NOT a dumb question at all. I too and interested in this answer. I can't answer your question but wanted to let you know it isn't a dumb question.
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 02-04-2011, 12:39 PM
bamasport's Avatar
Rep:186
ok, thank you all for explaining that. That was the assumption i was under but i just wanted to make sure. I am looking for a negative offset to push my tires out away from the swingarm. appreciate the help
JON
Old 02-04-2011, 12:41 PM
BLKSVT's Avatar
Rep:222
Yes sir, no problem...negative is out, positive is in.
Old 02-04-2011, 12:45 PM
bamasport's Avatar
Rep:186
one other question.... a -24mm offset pushes the wheels out about 4" is this what this means:
<LI class=wiki_listitem>-24mm Offset (4.5" backspacing)
JON
Old 02-04-2011, 12:51 PM
BLKSVT's Avatar
Rep:222
This may help you too...love google!
http://www.autolounge.net/calculators/tirespacing.html
2010 ram tires wheels, rims, rockstars, wheels
