Old 02-04-2011, 07:34 PM
PigzFly PigzFly is offline
Vehicle: 2010 Ram 1500 Sport CC
Trim Level: SPORT
Color: Black on Black
Rep:33
PigzFly is on a distinguished road
Default Thoughts on Exhaust change - :et me know what you think
I have been trying to decide what to do with my exhaust. I have a 2010 1500 Sport with stock exhaust. Id like to get a deeper throatier sound, while also looking for a bit of performance gain. I have been reading a lot of what guys have to say on here and it all seems to be muffler swaps, or cat-back systems. But I had an idea based on stuff guys do with nissan Titans (what I had before)
Being that the most restriction comes from the Ypipe and the muffler, what do you guys think about removing both and turning the system into true duals? Im talking about replacing the ypipe and the muffler with just two pieces of pipe from before the Y to after the muffler, where it splits back into two pipes. And then, instead of adding the muffler back in, just allowing the resonators before the tips to act as mufflers? Not sure how this will work. Titans use a dual cat system where the second one is used as a resonator. A lot of guys just pull the stock muffler and allow the second cat to act as a muffler.
Other options would be to pull the stock y and muffler and go true duals with two dynomax bullets. They sound pretty awesome.
Or just replacing the stock muffler with a CheryBomb extreme muffler which is a single in dual out. But then would either need to find a replacement Y or just deal with the stock.
Just hoping to get some input and/or advice. I dont know much about the ram exhaust setup, so anything will help.
2010 Ram 1500 SPORT Crew Cab
ProComp 6" lift - 22" XD Monsters w/ 35" Toyo MT's
Old 02-04-2011, 07:47 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Not sure about that. I did a new Magnaflow Y pipe in mine and replaced the muffler. The owner of the shop said it would flow way better and help keep the torque up. Here is my thread if you want to check it out. I don't know about the benefits of true duals, but I do know H-pipes help with torque and X-pipes are good for high end HP.
http://ramforumz.com/showthread.php?t=71908
Old 02-12-2011, 07:25 AM
Xtreme1's Avatar
Xtreme1 Xtreme1 is offline
Vehicle: 2007 Ram 2500 Quad Cab
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Xtreme1 is on a distinguished road
Not sure about the true duals. I ran a Flow Master HD 50 series on my 03 with 4 inch tips from the cat back. Sounds great and did provide a noticeable improvement in power. I also ran a Bully Dog Triple Gas programmer on it and it really came to life after that. Good luck and keep us posted.
Old 02-12-2011, 01:48 PM
tutter73's Avatar
tutter73 tutter73 is offline
Vehicle: 2010 Dodge Ram 1500 "Big horn"
Trim Level: SLT Big Horn Edition
tutter73 is on a distinguished road
I went with Superflow 40 series and cut out both resinators on my truck and i love the rumble it has. The problem i am having now is i can't keep my wife from driving it all the time. lol!
Old 02-12-2011, 01:54 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im not sure about the true duals either but i would just swap out the muffler and y pipe or just get a full cat back
Old 02-12-2011, 02:29 PM
916Timmy's Avatar
Rep:1443
Here's the cats outlet, so go from here out to the back!
And here is the crappy stock Y
Not a lot of room on the driver's side of the truck to work true duals, but I'm sure it could be done somehow. It's really easy to do the Y into a single 3"
Old 02-18-2011, 12:06 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I say... duals with an X-pipe.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
cat back exhaust change townsendpn Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 12-25-2010 12:49 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Exhaust Thoughts... ShotGunWillie 2009 Dodge Ram Forum 14 08-28-2010 08:49 PM
Factory rear dual exhaust change TRDon Exhaust 9 02-11-2010 04:56 AM
