tire question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-05-2011, 09:48 AM
ballcap ballcap is offline
ballcap is on a distinguished road
Default tire question
I have an 09 ram 1500 sport 4x4 with no leveling or lift kit. I found a deal on some rims and tires but do not know if they will fit, any help would be great!
here is the info: 36x13.50x15, Tires are bias ply,tires are mounted on 15x10 Simulated Beadlock black wheels, 3.5 backspace, 5 x 5.5 lug pattern
Old 02-05-2011, 12:30 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
I am quite sure that 36" tires are too big. 34" tires are the tip top of the scale, with 33"usually being the most recommended tire without a lift or leveling kit. You will rub with 36's. The main issue is the rim size though. I don't believe 15" wheels will fit over your brake calipers. Brakes are now larger on modern pickups and that is why most come out with 16 or 17 inch rims as the base size.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 02-05-2011, 01:18 PM
No, these will not fit your truck for the reasons stated above. You need a lift to clear that big of a tire and the 15" wheels will not clear your brakes.
Old 02-05-2011, 02:26 PM
Rep:1625
^^^ What they said
Old 02-05-2011, 03:04 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
If it's your daily driver I wouldn't recommend the bias ply tires either.
Old 02-06-2011, 04:41 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
My 34" rubbed prior to the level kit
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Question about spare tire kot333 2010 Dodge Ram Forum 0 12-02-2010 08:36 AM
2004 Ram 4X4 Tire Fit Question???????? 04ram4X4 Dodge Ram Wheels And Tires 4 06-29-2010 10:32 AM
Question about my spare tire YoMoma Dodge Ram Wheels And Tires 7 04-07-2010 01:43 PM
