Old 02-05-2011, 02:40 PM
kozzy kozzy is offline
Vehicle: 2015 Ram 2500 Big Horn
Color: Deep Cherry Red
kozzy is on a distinguished road
Default Aftermarket Radio Install
I am looking to upgrade me radio to aftermarket stuff I had in my old car. Anyone know the correct harnesses I need for hookup and retaining my steering wheel controls?
Also, speaker sizes for the doors...i have seen so much conflicting information, I have a set of JL Audios i would really like to use, and was thinking bout purchasing a set of 5 x 7 for the other doors, and the 3.5 for the dash. Any insight or information would be great. Thanks
Old 02-05-2011, 03:15 PM
Welcome to the forum. Here's a link to PacAudio's website. Put your truck's info in the Product Search area and see what they have for your truck.
http://www.pac-audio.com/
I am not sure on the speaker sizes. I know my stock MegaCab speakers were 3.5" in the dash, 6X9 in the front doors, 5.25" in the rear doors.
So I went to Crutchfield and looked up your truck. They list 3.5" for the dash, 5.25" for the front doors (with the right adapter you can go to 6.5") and the rear doors look to be the same as the front doors. You do need a shallow mount speaker and I am not sure just how much depth you have but you could measure that easily enough. For some reason, 2 - 5/8" sticks in my head from some other thread on 2011 audio.
Good luck!
Old 02-05-2011, 03:16 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
3.5" dash speakers and 6X9 in all 4 doors! Try the audio section and see if someone there can help you out!
Old 02-05-2011, 03:30 PM
Broke74 Broke74 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Quad Cab 4X4 BigHorn
Rep:35
Broke74 is on a distinguished road
I'm looking to do an upgrade as well.
I've always gone through Crutchfield because they send the correct harness and detailed installation instructions. Not to mention, the customer service can't be beat.
Old 02-05-2011, 03:40 PM
Rep:2657
INSTALLER.com also supplies everything you may need or want
Old 02-05-2011, 05:14 PM
Default thanks
Thanks for the info. I am using crucified but was finding conflicting info. The y don't have much info on the 2011 I'm pretty sure the doors are all 6 x 9 but the jl audio I have need like 3.75 inches depth. I have also read that the pac adapters had some sort of the delay with the steering wheel controls. There is one by axxes which looks to be better..anyone ever use it?
Old 02-05-2011, 05:24 PM
I use my steering wheel controls with the pacaudio harness and I experience no delay.
Old 02-05-2011, 11:14 PM
Default pac adaptor
Maddog,
there are 2 pac audio adaptors i found on Crutchfield, one for the radio hook up, and one for the steering wheel audio control. However, the radio integration adaptor says it does the steering wheel controls. Did you need both adaptors, or just one?
Do you haappend to know the part numbers you used?
Thanks again
2006 Ram aftermarket radio install jerzey111 Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 08-27-2012 07:24 AM
Aftermarket radio installation DuNW8iNg Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 07-04-2009 05:25 PM
weird aftermarket radio problem kineticenrage Custom Dodge Ram Interior Modifications - Custom Audio / Video 10 06-23-2009 07:24 AM
Signal To Aftermarket Amp With Stock Radio? BLACK07 Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 06-08-2009 09:30 AM
Aftermarket Radio Help ShanghaiPaddles Custom Dodge Ram Interior Modifications - Custom Audio / Video 15 02-08-2009 07:05 PM
