Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-05-2011, 11:31 PM
arsonhntr's Avatar
arsonhntr arsonhntr is offline
Vehicle: 2004 1500 Ram SLT
Color: RED
Rep:53
arsonhntr will become famous soon enough
Default losing coolant.
My 04 5.7 is losing coolant. Ive noticed that the reservoir will go from the full mark to the low mark within a week or so. Also there are no visible leaks anywhere. Every now and then when driving I will get a very faint smell of engine coolant but it quickly disipates. The engine is not overheating and I am on the interstate 90 pct of the time. And, on a totally different question, when I check my power steering fluid the when the cap is removed it seems to be under pressure, is this normal? BTW, I changed the spark plugs today and cleaned the throttle body. Thanks to this forum and the "techs" that provide us with tips and instructions/advice, it wasn't bad at all!
Old 02-05-2011, 11:41 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is online now
Vehicle: 2016 Ram 2500 4x4 LongHorn Meg
Trim Level: LongHorn
Rep:127
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
You mite need a new rad cap
2500 Megacab 4x4
Longhorn Brilliant Black Pearl 6.4L
Cattle Tan Interior
Old 02-06-2011, 12:08 AM
It could be a loose hose clamp , leaking radiator , radiator cap , heater core etc.....If you have the worm gear hose clamps , give them a tweaking . Look at the radiator closely . It could have a seam laeaking . Let us know what you find .
Old 02-07-2011, 03:34 AM
Pride0aries's Avatar
Pride0aries Pride0aries is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
Color: Patriot Blue/Silver
Rep:55
Pride0aries will become famous soon enough
If you smell it, either the fresh air intake for the cabin is picking it up from a leak (cap or hoses prime suspects) OR heater core/fittings loose or leaking. Given that kind of volume, you'd notice heater related stuff pretty quick I'd think. I don't if they're much in use any longer, but I used to test coolant systems with a hand pump that screwed onto the neck in place of the radiator cap. It would pretty quickly spot leaks that don't happen when it's cold, and it's not always practical to find when the motor is hot.
2003 RAM 1500 Quad Cab Patriot Blue/Silver
Coolant dissappearing sritter Heating & Cooling 13 12-29-2010 05:09 PM
Tranny Fluid in Coolant Reservoir? Deez Nutz 4.7L PowerTech V8 Specific Topics 1 11-05-2010 01:49 PM
Coolant leaking from AC Compressor...WTF? 96Ram1500 Heating & Cooling 8 09-26-2010 10:08 PM
Losing coolant HemiHamma 5.7L V8 Specific Topics 6 03-10-2010 10:40 AM
Coolant leak. Bad rad? bigdaddyII 4.7L PowerTech V8 Specific Topics 17 12-16-2009 08:26 PM
