Old 02-05-2011, 11:34 PM
Zippo973 Zippo973 is offline
Vehicle: 2011 Dodge Ram
Color: Black Pearl
Rep:42
Zippo973 is on a distinguished road
Default 2011 foglight question
Hey everyone, I'm working on a 2011 Ram 1500 and am adding on the Mopar Foglights. They fit perfectly but when I try to wire it up to port 23 and port 24 slots in the green C3 26 way connector, there were already wires there. I found two other empty slots that had connector pins and put the wires there, but I don't think that is gonna work cause the fog-lights come on every time I hit the brakes. I would like to fix it before I take it to the dealer for the code work. Anyone dealt with this issue before? thanks zip
Old 02-06-2011, 12:01 AM
Have you checked to see if your truck already has the wiring harness there in place ?
Old 02-06-2011, 12:16 AM
Color: Black Pearl
Rep:42
These are the fog lights that would be dealer installed and they have there own harness that gets plugged into the lights and thentwo wires and a ground go into the TIPM box. But were the manual says the wires should go... there are wires already installed.
Old 02-06-2011, 12:20 AM
That why I was thinking your truck may already be wired for them .
Old 02-09-2011, 02:05 AM
Color: Black Pearl
Rep:42
found out that 2009-2010 are wired the same but 2011's have a different TIPM so all the wired accessories are in different spots. It was not prewired for the foglights. I took a lot of jazz from the guys at work when they saw me pull in and step on the brakes and have the fog lights come on. Gottem workin now though
Old 02-09-2011, 10:30 PM
jrsjf jrsjf is offline
Color: WHite
jrsjf is on a distinguished road
Hey Zippo, im having the same problem. Where did you put the wires to get them to work. I had my computer programmed but dont have the wires in the correct spot to get them to work. I also had them in the break spot and had them turn on when i hit the break. Any help here would be great.
Old 02-10-2011, 01:39 PM
Color: Black Pearl
Rep:42
Look for the 16 pin C4 connector should be light gray or beige. Mine was located below and to the left of the green C3 26 way connector. Holding the 16 pin connector up so the red connector lock in on top, the top right pin would be port 1 and the bottom left would be port 16. You need to put the white w/orange wire in port 11 and the white/yellow in port 16. You might find a black sin those positions they are dummy wires and I just taped them up. Hope that works for ya . Post when your done to let us know. zip
Old 02-10-2011, 04:51 PM
Color: WHite
Thanks, Im going away this weekend but ill give it a try when i get back thanks.
Old 02-20-2011, 06:19 PM
Color: WHite
I ended up taking my truck to the dealer since it had to be programmed and they were able to get them running. Thanks for your help though.
Old 02-22-2011, 08:22 PM
Apache08075's Avatar
Apache08075 Apache08075 is offline
Trim Level: BigHorn 4x4
Apache08075 is on a distinguished road
Hey do you have a picture of the finished fog lights installed? I'm debating to buy the factory mopar setup, or go after market.
fog lights
2011 Outdoorsman lift question readeth Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 02-07-2011 02:16 AM
Question on performance parts 2011 Dodge Ram R/T el RT7 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 01-25-2011 05:45 PM
Question on installing CAI on 2011 Ram kap64 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 11-23-2010 04:22 AM
2011 Ram performance mod question Bighert3rd Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 09-25-2010 11:16 AM
