Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Place your Ad Here!
Old 02-11-2011, 11:10 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Until you have lived through a blown motor from not dialing in with a wideband/AF gauge and trying to not seek getting a dyno tune....because you feel you can do it, because you've read soooooo much on the internet about how easy it really is. Well, then I say that 15k motor may prove to be an expensive lesson to learn.
I just don't understand why y'all wouldn't just buy a flex fuel vehicle to begin with?
But good luck and I hope it works for everyone trying to do it, my .02 of input is just that, I have no dog in this fight and can promise you I wouldn't be changing mine over to that even if gas gets to $7 a gallon.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 02-11-2011, 03:00 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
I agree that if you are gonna take things to the limit as in a blown engine, ya better be sure what you are doing, however, I don't corrolate the restraints of that particular mod with running E-30 in a modern non-ffv vehicle.
I'd love to have Dodge offer a FFV version of the 5.7. Looked twice at the 4.7 because of this capability, but, as has been the case in the last 10 years, I've always opted for the highest HP N/A engine available from 'the MFG of choice' in a RCSB truck. (N/A due to pricepoint, but them ol' Lightnings sure are sweet!)
Not sure how it will all play out,,, I have months worth of testing to do in different climates and conditions before I can definately say E-30 is or isn't right for me, my vehicle, my conditions, etc etc etc. If in the long run it proves to be a flop, I won't move on to E-85. (Results thus far have been very promising, but until I get 'months' worth of testing in w/different blend ratios and different temps, I can't swear to it as a cold, hard FACT)
Would still like to hear any results, both short and long term, from the OP.
Old 10-11-2013, 07:21 AM
Gottarpon Gottarpon is offline
Vehicle: 2010 Ram 1500 Big Horn 4X4
Color: Vanilla
Gottarpon is on a distinguished road
Thought I would raise this back up. More and More E85 everywhere and wondering is more 5.7s have made the switch.
Old 10-21-2013, 02:44 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I just finished reading the section of my 2013 owners manual on E-85 use in the 5.7 Hemi Engine. It indicated that the use of E-85 could result in damage and void the warranty. Do not use gasolines containing Methanol or E-85 Ethanol. Use of these blends may result in starting and driveability problems and may damage critical fuel system components.
Owners Manual Page 523:
Ethanol.
Problems that result from using methanol/gasoline or E-85
ethanol blends are not the responsibility of the manufacturer.
While MTBE is an oxygenate made from methanol, it
does not have the negative effects of methanol.
E-85 Usage In Non-Flex Fuel Vehicles
Non-FFV vehicles are compatible with gasoline containing
10% ethanol (E10). Gasoline with higher ethanol
content may void the vehicle’s warranty.
If a Non-FFV vehicle is inadvertently fueled with E-85
fuel, the engine will have some or all of these symptoms:
• operate in a lean mode
• OBD II “Malfunction Indicator Light” on
• poor engine performance
• poor cold start and cold driveability
• increased risk for fuel system component corrosion
To fix a Non-FFV vehicle inadvertently fueled once with
E-85 perform the following:
• drain the fuel tank (see your authorized dealer)
• change the engine oil and oil filter
• disconnect and reconnect the battery to reset the
engine controller memory
More extensive repairs will be required for prolonged
exposure to E-85 fuel.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 07-01-2016, 08:58 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I'm going to bring this up again. Basically e-85 is now cheap it +100 octane. And it's almost 1$ per gallon cheaper in Illinois. So who is running an e85 tune. All it does is burn super lean causing the sensors to go crazy trying to adjust everything. A good tune and it should be like race gas
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-04-2016, 01:49 AM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
An update to this would be nice. Anyone have any further information?
Old 07-05-2016, 03:06 PM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:167
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
Well my .02$ is that E85 IS like 110 octane race gas that when you have a 2nd tune on standby to use with it you can get mad power. All the fuel system items in your 4th gen trucks WILL have seals that resist ethanol because of the 10% allowed rule.
Only thing you will really (possibly at that) need is slightly larger injectors to see the full benefit.
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
