Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-06-2011, 12:52 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Default Fan questions
I installed superchips on my truck and after messing around with it alot I noticed my electric fan will not shut off, I can't figure out what the stock on temp for the fan is (superchips says "LOW 118DEG, MED 118DEG, AND HIGH 222DEG(If I remember correctly), so I'm assuming the 118 is a glitch. Do these trucks have 3 speed fans? The 222 seems right, but what should the low and med be set at? Also does anyone know what the stock thermostat temp is? Thanks in advance! (I know this is a superchips glitch but wanted to know these on temps for myself anyway). Oh, and why do these trucks have electric and clutch fans....?
Sean
Old 02-07-2011, 10:24 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
stock t-stat is 205 degrees.
sorry I can't help on the rest but the 118 degrees is def a glitch. Should prob be something around 200 and 210 but I'm just guessing.
Old 02-08-2011, 01:19 PM
snrusnak's Avatar
Rep:1385
Thanks for that info, I'm going to set it for 210 and 215 until I hear back from superchips tech...
Sean
Old 07-02-2011, 02:13 AM
bigred bigred is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: crome
Color: infernal red crystal pearl
bigred is on a distinguished road
hi I got mine set to 202 I usely see 203 and 204 today with 99 outside with my tuner you can set to run all the time and only when the ac is on I m thinking of going with the 180 t stat not sure if it will help but like around 200 on my temps on a hot day
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 03:12 PM
Returning Ram owner, new to forum, lots of questions. Jdboxer02 Newbie Checkin! 11 01-03-2011 02:08 PM
Lowering questions HEMIBLUDA Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 06-20-2010 07:28 PM
Couple questions Quiet Lunatic Electrical 4 09-11-2008 08:45 AM
