Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-21-2011, 07:11 PM
Xtremehumpdog Xtremehumpdog is offline
Vehicle: 2001 Ram 1500 Sport 4x4
Xtremehumpdog is on a distinguished road
This is my last update and what I have learned. After many hours of work I figured out my issue. From the check valve on the passenger side of the engine compartment it goes through the firewall into a reservoir under the wiper cowling. I was puzzled by this as I could not find where it actually entered the cab and no one not even the dealership could tell me. I removed my dashboard completely and found no where on the firewall was there a supply line. I did find out the heater core was replaced recently. So I ran my own vacuum line aft of the check valve and into the cab. This possibly might be the way it's suppose to be run factory. I used the firewall entry for the antenna. Now my vents function as they should. I plan on finding another dodge and seeing if I can figure out where it's suppose to come through. Thank you everyone for your help. And on the brighter side I am now a guru when it comes to vacuum lines...LOL
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Drivers door lock switch......... bigdaddyII Electrical 9 01-25-2011 11:09 AM
horn separate switch dead short..help! String13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 12-31-2010 09:20 AM
My trucks flashing a P0420 and a P0442 code jcasey10 5.9L V8 Specific Topics 10 09-15-2010 02:10 PM
Need help w/ HVAC damper actuator vacuum line wiring Quiet Lunatic Body & Interior 2 12-12-2009 08:43 PM
