Old 02-06-2011, 06:28 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Default Want to install some interior lights
So I have read and can agree that the ST Ram does not have the best interior lighting what so ever. What I have decided to do is to install some small directional LED lights on the bezel some where, maybe just below the A/C knobs, to shine down on the fold out cup holder.
What I don't know and can't find on here is how to wire them so they come on when the rest of the interior lights come on. I do have auto lights so I think that would be cool to have the LEDs tapped into that circuit.
Any help or thoughts please!!
Old 02-06-2011, 09:58 PM
I push the skinny pedal
Rep:3308
In your driverside A-pillar, the line running to your dome light; I'd tap into that line and run a set of LEDs off of it. I have tapped into mine and am running about 15' of led strips off of the stock line with no issues.
Kurtis
Old 02-06-2011, 10:03 PM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
You should be able to just run a wire up through one of the side pillars to the map lights. Just find the wire that has +12 volts on it when the door is opened using a volt meter. You might want to run another wire from the switch on the dash though so can turn the lights on manually.
Old 02-06-2011, 10:06 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I have mine spliced into there and everything works great.
Dillon-aka, The Little Kid
Rep:79
But will that give me the desired effect? Which is that the lights auto turn on when the rest of the interior lights turn on. I'm not an electrician but seems like if I tap into the dome light wire then the LED would only come on when the dome light does.
Old 02-06-2011, 10:30 PM
Rep:1338
It would come on every time your domes come on. Like when you open the doors they will come on along with the other lights.
Old 02-07-2011, 10:47 PM
Rep:79
Does anyone know how to tap into the auto light circuit to have add-on light work in conjunction with the dash lights?
Old 02-10-2011, 03:46 PM
racer48's Avatar
racer48 racer48 is offline
Vehicle: 2007 Dodge Ram 1500
Color: chrimsin Red
racer48 is on a distinguished road
either do it yourself or have a stereo shop install a positive wire for you through your accecesories wire under the dash then you can put in a toggle switch somewhere to turn them on and off when ever you want but it wont kill your battery because they only come on when you turn the key but engine doesnt have to be running. ive got flex LED lights mounted under the dash on driver and passanger side and they create a cool effect then just ran a ground wire to the back of the truck and drilled into the metal brace under the seat and used a self taping metal screw and wiring connector. make sure to scrape off the paint then repaint it so it doesnt have any way of rusting
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
HID INSTALL SOLUTION for anyone that cares silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 3 08-26-2013 09:54 PM
OEM Foglights Install CdnoilRAM Dodge Ram Knowledge Base 23 08-24-2011 09:49 PM
HID Install 09/10 RAMS doz Custom Dodge Ram Interior and Exterior Lighting 14 03-20-2011 02:28 AM
Computer won't install device driver? wickedpissahtruck Diablo Predator Questions & Info! 5 11-08-2010 06:28 PM
