Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 02-06-2011, 07:27 PM
jmcamille jmcamille is offline
Vehicle: 1997 dodge ram
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
jmcamille is on a distinguished road
Default Engine oil seal where power steering shaft attaches
I have a 97 Dodge Cummins 3500 First off I wanna be clear that I am correct... where the power steering pump mounts to the engine... does the engine oil lubricate power steering shaft? I have a huge oil leak coming from where the 2 connect and also was wondering if anyone has already done this and how hard it was. Any help is appreciated!
Old 02-07-2011, 10:10 AM
Resident Technician
Rep:1909
Only if you have a bad leak! Engine oil has nothing to do with the power steering.
Old 02-10-2011, 01:37 PM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
I am also a TDR member ( Turbo Diesel Register ) this is what you need. I have used them before simple instructions with a dvd to and spare parts too. ( www.fixinrams.com )
Bodine
Old 12-16-2013, 10:16 PM
Rynclark Rynclark is offline
Vehicle: 1998.5 RAM 3500
Color: Grey
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rynclark is on a distinguished road
I had this same problem in my 98 and the steering pump housing was cracked. Yes it is engine oil leaking out of there. I opted for a used part from a wrecker but you can get a new part and they aren't cheap. Also it isn't super easy to replace as it is in a tight spit but can be done
Old 07-08-2015, 06:44 PM
windgirl's Avatar
windgirl windgirl is offline
Vehicle: 1998 Dodge Ram 2500
Trim Level: Laramie SLT
Color: green/gray
windgirl is on a distinguished road
Thanks guys for the clear answers. My truck is a mess of oil with a leak coming out of there. A mechanic told me he did a gasket change for a customer before - same kind of issue. I hope that is all there is to it. I intend to take the pump out and do the gasket job. Hope the pump casing itself is not cracked. And that once the zone is cleaned there is no other leak under my truck. What a mess.
power steering leak 94beast 5.2L V8 Specific Topics 2 11-01-2015 01:04 AM
Octane Rating (good info) Jay Fuel System 21 06-08-2011 02:02 AM
Power steering fluid leak rockymtnmopar Cummins Diesel Specific Topics 5 05-04-2009 08:57 PM
Octane Rating (good info) Jay Dodge Ram General Discussion 3 03-27-2009 09:30 AM
