front axle actuator - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-14-2015, 02:31 PM
Barry H Barry H is offline
Vehicle: 2014 crew cab 1500
Barry H is on a distinguished road
Default front axle actuator
hi everyone i don't know if this is the right area to post but here it is. looked around and used the search area but not to good at finding things. my son has picked up a 96 2500 diesel with a automatic trans. after moving it around a few times this winter it has developed a little problem, the actuator valve seems to have a hole rusted through it. any info on how to change this or advise. thanks in advance Barry
Old 07-04-2015, 11:21 AM
12Valver 12Valver is offline
Vehicle: 1996 Dodge Ram 2500
Color: Blue Pearl / Driftwood
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
12Valver is on a distinguished road
Hi Barry....I also own a 96 & had same problem. A corrosion hole in actuator (amongst so much other rusting issues...it's sad). I don't remember where I picked up a new actuator from but replacing it was a pretty simple job. Once these actuators get holes, because it works off of vacuum, it will not work. Must be replaced. Also check the tubing vac lines that operate it. They're probably almost gone as well. I reaced mind with rubber vac hose. 4 bolts that hold it to the axle. Make sure you get the whole assembly. Comes with a gasket as well. Just make sure the "fork" is aligned when you re-install. You'll see what I mean when you pull old one out. Good luck......Mike
