Old 02-06-2011, 09:56 PM
jeepinoutwest jeepinoutwest is offline
Vehicle: 2011 Ram 2500
jeepinoutwest is on a distinguished road
Default Is this HBS sway bar drop kit installed correctly?
Ok just so you dont think Im crazy. I installed a Hell Bent Steel sway bar drop kit. The instructions show a picture of the brackets pointing forward, however the only way I could get the sway bar links to be vertical is to have the brackets point rearward? Are these pics correct? Did I do this correctly? Thanks
Old 02-07-2011, 09:45 PM
So I got the answer from Hell Bent Steel. The sway bar drop brackets can be installed in either direction, whichever works better for your application so that you can get the sway bar link to be vertical. So, my pics are correct. Hope this helps someone out there.
McGaughys 2-4 drop installed fuzzycali 2009 Dodge Ram Forum 56 11-07-2010 07:50 PM
ram rt ordered new sway bars, drop kit, shocks SPEEDFREAK Dodge Ram R/T 14 09-08-2010 11:17 AM
Got the GroundForce 2/4 drop installed CdnoilRAM Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 19 06-18-2010 12:16 PM
sway bars strang3majik Suspension 0 06-10-2010 01:28 AM
Ball Hitch Drop Ken Towing 5 05-10-2010 08:51 AM
