Old 02-06-2011, 11:04 PM
jstang's Avatar
jstang jstang is offline
Vehicle: 2011 Ram 1500 5.7
jstang is on a distinguished road
Default Seatbelt light
Is there anyway to shut off the seatbelt sensor on a 2011 Ram. The beep gets kind of annoying. I know on the crown vics there is a way to do it by inserting and removing the seatbelt several times with the key in a certain position, does dodge have anything like this?
Old 02-07-2011, 07:18 AM
mrroader14 mrroader14 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: outdoorsman
Color: deep water blue
mrroader14 is on a distinguished road
My 2006 did have a way to do that, but I haven't found or seen anything on the 2011 yet to do it. Thinking maybe now its law they may have done away with it, but I don't know for sure
Old 02-07-2011, 08:23 AM
2011Ram's Avatar
2011Ram 2011Ram is offline
Vehicle: 2011 Ram Sport QC 4x4
Trim Level: Sport Premium
Rep:85
2011Ram will become famous soon enough
I don't know why you wouldn't just wear it, it could save your life so that you can enjoy your vehicle. Unless you'd sooner be dead if your baby got smashed up.
Old 02-07-2011, 09:29 AM
shrek shrek is offline
Vehicle: 2013 Ram 1500 CC Sport
Rep:38
shrek is on a distinguished road
there is a post on here search: disabling seatbelt chime
Old 02-07-2011, 10:17 AM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
for the 2010, you latched the seat belt and turned the key on until you hear the chime. then you proceed to unlatch and relatch the seat belt 3 or 4 times, ending with the seat belt inserted and shut the truck off. if it works you will hear 3 chimes. it will not turn off the red seatbelt light but it will turn off the chime.
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 02-08-2011, 04:08 PM
johnnyh
I disabled my brothers from a plug below the seat, but now i wonder if that will screw him or a passenger over. If it does not recognize them in the seat, will the airbag go off, need it be. Its an annoyance but it might be the difference between life or death, purely speculation, it may not work that way
Old 02-08-2011, 04:31 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Options:
1. Wear the seat belt.
Disconnecting it below the seat will mess with the airbag too and probably throw a code.
Brian:
Old 02-08-2011, 09:38 PM
doug713's Avatar
doug713 doug713 is offline
Vehicle: 2011 Dodge Ram
Rep:33
doug713 is on a distinguished road
I agree with RootBeer,, wear your dang seatbelt. thats the easiest and sure fire way to turn off the seatbelt light and chime...
Old 11-09-2014, 07:48 PM
VINCENTR VINCENTR is offline
Vehicle: 2002 Dodge Ram 3500
Color: red
VINCENTR is on a distinguished road
How do you enable a disabled seatbelt chime. I have a 2002 Dodge 3500. The seatbelt light will not go off and it does not chime when the seatbelt is unlatched.
Old 11-09-2014, 09:46 PM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:139
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
I disabled my seat belt chime only because I do a lot of driving around the property at work and I have family that live right around the corner in our nieghborhood.
When I actually drive on the road my seatbelt is the first thing I do before I even start the truck.
As far as enabling your seatbelt chime if you know the process to disable it do the same thing to enable it... At least that is how it normally works. If your not sure of the process check your owners manual it may be in there or Google it.
Check my mod list.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Engine Light update kgb503 2010 Dodge Ram Forum 4 01-31-2011 08:25 PM
HID Colour Choice mineralram 2009 Dodge Ram Forum 11 03-09-2010 11:02 AM
