Old 02-07-2011, 11:52 AM
BgHickson BgHickson is offline
Vehicle: 2002 Dodge Ram
BgHickson is on a distinguished road
Default Will these Tires rub?
I know this question has probably been answered on here before but...
I have an 02 Ram Quadcab 4wd. I was wondering if 305/55/20's would fit with out rubbing or not? Or would i have to go down to the 305/50/20?
Thanks for your help.
Old 02-07-2011, 12:29 PM
A 305 will be a tight fit. The 55 isn't too tall but the section width of 305 will probably rub at full steering lock.
I'd go to a local tire and wheel shop and try a test fit!
Old 02-07-2011, 01:05 PM
Thanks!!!! I really appreciate it.
Old 02-07-2011, 02:09 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Yeah mine rubbed had to put 1/4 inch spacer on em have 305 55 20 trail grapplers but my 305 35 24s do not rub...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-07-2011, 06:28 PM
ScatPak07's Avatar
Rep:970
Yea the 305 is pretty wide for a stock sitting truck. If you get a leveling kit you should be alright. I had the 305/55/20 on my 07 Ram with a 2" lift and there was only rubbing at full lock. I have the same tires on my '11 Ram stock set up and I have rubbing at full lock. So with that said you will have rubbing at full lock haha.
If you go and get a wheel spacer or an aftermarket wheel with a negative offset you should be good to go!
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 96 01-16-2016 08:50 AM
Need Some Help and Pics Would be Awesome! (Tires) ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 02-04-2011 03:19 PM
so pissed off regarding tires and rims mineralram Dodge Ram Wheels And Tires 7 08-28-2010 12:20 AM
New Tires Already! tbagr09hemi 2009 Dodge Ram Forum 15 08-21-2010 05:51 PM
What do you think of these tires??? ScatPak07 Dodge Ram Wheels And Tires 19 07-25-2010 09:00 PM
