Old 02-07-2011, 06:44 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
Default I have no clue!!!!!
Ok I have a 2001 Ram 1500 5.9. Although my engine is not the issue I have a very strange issue with the transmission that I cant even the local repair shops to tell me what it is.
Here it is: When I start the truck when its cold the transmission is very sluggish and doesnt wanna go almost like its starting in 2nd gear. so when i drive to my destination I have to give it time to get up to speed if I put the throttle all the way down it wont exceed 2500 rpm and im just wasting gas. when the trans warms up and i shut the truck off and start it again I have 1st gear again it wants to go go go!!! only problem is it doesnt wanna shift till 3500 rpm or more. A couple of times i had to pull over and shut it off cuz it would shift at all. Eventually If I turn it off and restart it enough itll go back into 2nd again (which i try to avoid cua turning on and off can be bad). I have had 2 repair shops tell to change the fluid which i have already done before calling either of them. 1 shop tells me i need a new govener but cant explain why it switches back each time I start it up. they want $100 to look at it nonrefundable cuz they think its a waste of time. I think its electrical but have no idea where to start.
If any one has any advice or has had this problem in the past i would really like to know what it is and how to fix it!!!
Old 02-07-2011, 09:44 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Does it feel like you have a real high stall converter? like it's slipping?
Old 02-08-2011, 10:51 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
there is like solenoids and switches and everything inside the transmission im not sure how all that works i think the only way to figure out if there bad is getting it rebuilt but ive never heard of that
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-08-2011, 04:04 PM
sixwheeler sixwheeler is offline
sixwheeler is on a distinguished road
My truck is sluggish in the morning when the truck is cold. but after it warms up it runs fine. So idk.
Old 02-09-2011, 08:39 AM
98redbull2's Avatar
Rep:52
mine is too but mine has 260,000 miles on it lol thats prolly why but im not sure
Old 02-15-2011, 02:29 PM
TLars's Avatar
TLars TLars is offline
Vehicle: 1998 Ram 2500 4wd
TLars is on a distinguished road
Mine was doing something similar - ran good cold but when the fluid was hot it was swishing past seals causing it to hold the gears and would have to manually shift them with the column lever.
Check the fluid when warmed up - are there any bubbles in the fluid? If so, you will have faulty seals and will need to replace them. Basically an overhaul kit. That's what happened with mine then they found the 1-2 internal clutches were toast!
Mods: Superchips; Spectre CAI; Magnaflow duals; 180* thermostat
Old 02-15-2011, 02:34 PM
Resident Technician
Rep:1909
Solenoids, switches and sensors are not replaced during a rebuild unless diagnostics reveal a problem before the build.
Old 02-15-2011, 02:36 PM
Resident Technician
Rep:1909
It sounds to me like you have a problem that is causing the trans to go into limp-in mode (staying in second gear all the time). Have you had the TCM scanned for codes?
No clue what I'm doing 21blueyes Dodge Ram General Discussion 4 02-05-2011 07:08 PM
Under Glow Stopped Working 2001RAMSPORT Custom Dodge Ram Interior and Exterior Lighting 20 01-03-2011 10:42 PM
Vibration, any ideas. Dealer didn't have any clue. PowdaSuga 2010 Dodge Ram Forum 6 08-03-2010 09:42 PM
Dash Bezel? Stoner421 Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 05-25-2010 04:20 PM
