Old 02-07-2011, 06:37 PM
hillvalley hillvalley is offline
hillvalley is on a distinguished road
Default 1994 dodge ram check engine light- wont idle sometimes
I have a 1994 Dodge ram 1500 318 automatic with 160,000. The check engine light has come on. and will not idle sometimes.. I replace the idle air control valve about 3 months ago when is was acting up up before the the engine light was never on then.. Now this problem has emerged.truck runs fine as long as your foot is on the gas...Could my idle are control valve be junk again? if i checked the code right it is telling me the idle air control motor circuit is one of the codes but couldnt imagine it being bad already..need any help i can get. thanks
Old 02-08-2011, 03:04 AM
Devin32 Devin32 is offline
Vehicle: 2007 dodge ram
Trim Level: st
Color: electric blue
Devin32 is on a distinguished road
could of been faulty. but it could be anything, try tapping on the mas air flow sensor with a wrench. sounds odd but sometimes thats all it takes.
Old 02-09-2011, 08:04 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
the second generation ram doesnt have mass air flow sensors, the only thing controlling the idle is that valve and if you have to make it idle with the gas pedal then its probably bad id try replacing it again. i dont know of anything else that would make it not idle unless it was running really bad.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-16-2011, 11:02 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Did you buy OEM? 99% of aftermarket parts are not up to par and will go bad fairly quick.
Old 02-16-2011, 11:22 AM
RamTech RamTech is online now
Rep:1885
Could also be a PCM or wiring issue.
Old 10-24-2011, 11:07 PM
razmataz razmataz is offline
Vehicle: 2009 RAM TRX4
Color: yellow
razmataz is on a distinguished road
engine controllers memory may need to be reset with a dealer scan tool.
Old 10-25-2011, 10:35 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Or just disconnect the battery for a few minutes, touch the two leads together, then reconnect. Also, make sure that intake plenum gasket isn't leaking.
2009 TSBs BlueJet 2009 Dodge Ram Forum 38 10-28-2014 05:03 PM
check engine light MOPAR stallion 5.9L V8 Specific Topics 24 11-26-2010 03:12 AM
check engine light? factory warrant? bigram510 5.7L V8 Specific Topics 6 04-08-2010 07:27 PM
Check engine light? 04ram4X4 5.7L V8 Specific Topics 8 04-03-2010 12:27 PM
check engine light 96blacky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 06-04-2009 04:27 PM
