Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 02-07-2011, 10:26 PM
05akram 05akram is offline
Vehicle: 2005 qc 1500
05akram is on a distinguished road
Default reading knock
Sorry Im new to the dsp. I decided to hook up dsp to check for knock today. When I am recording live data there is two parameters going. The first one moves around a little bit while I drive around. (starts @ 15 and goes down from there.) They other one stays @0.
I guess my question is this normal. Im guessing the second one is degrees in KR? but Whats the first representing and is it supposed to move? Is this the timing advancing or something?
Old 02-13-2011, 12:25 AM
I'm not sure myself . Hopefully someone can help ya out . Have you contacted Diablosport ? They do have a decent FAQ section . You may find your answer there .
Old 02-13-2011, 12:02 PM
yea I got it all figured out and im OK to go.
Old 02-13-2011, 04:55 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
This is where you teach all the rest of use novices on the DSP and give us the answer to the question you discovered................
Old 02-13-2011, 06:14 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Its normal to see some knock in the 2009-2011 rams.
But you should only be seeing it at certain places.
Usually when flooring it you will see some knock for a few seconds,and again from a dead stop if you floor it also.
The only time you need to worry about it,is if you see the knock continues to rise when accelerating.
Diablo has the best datalogging software of any programmer out there.
If you monitor st(short term) knock,and LT(long term knock),you should only see st knock when datalogging.
If you see LT knock numbers then you know your truck is pulling timing,and that means you do have a problem.
Even changing out your exhaust and not using all your exhaust hangers can cause enuff vibration to trigger some knock.
The last thing you should ever do is touch your knock sensors or adjust them.
If you have knock It is Not because of a bad sensor,but check the tq on the sensor just the same.
I quite often see about 3-3.5 % knock when im trying to floor it while driving,but it goes away right away.
Another thing worth checking is to monitor all 8 cyclinders for misses,you can monitor each individual cyclinder,this will help you trouble shoot,to make sure its not a bad coil,or spark plug wire causing the problem.
I run Superchips Now but wish I had my old Diablo for datalogging.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 02-13-2011, 07:35 PM
Crash's Avatar
Rep:401
Thanks for the explanation Catsltd, there's some rep in it for you
Old 02-14-2011, 04:38 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
It would be nice to have a visual aid to see what the gauges look like and a more in depth explanation of what the engine is doing to create knock and what the proper solution is to help prevent damage to our engines. Specificly with the Trinity.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-14-2011, 04:41 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
wow never knew the Diablo could do all this Im running a superchips in the Ram just b/c it worked good for my Dakota after reading that it can do this I might be picking up a Diablo next thanks for all the info
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 02-15-2011, 03:28 AM
yea. My problems were that I wasnt reading the LT and St knock readings or my knock voltage. I was watching some other parameter. It was a huge relief. This dsp is sweet.
Octane Rating (good info) Jay Fuel System 21 06-08-2011 01:02 AM
Regular gas in a 2010 ram with a hemi? Ray Dodge Ram MPG Zone 31 01-20-2010 11:04 PM
What kind of gas do you use?????? bransonshemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 61 12-08-2009 09:38 PM
Octane Rating (good info) Jay Dodge Ram General Discussion 3 03-27-2009 08:30 AM
Cold Engine knock 95 ram 5.2 liter kccoln 5.2L V8 Specific Topics 3 02-17-2009 05:03 PM
