Old 02-08-2011, 01:38 AM
2010NebBigHorn's Avatar
2010NebBigHorn 2010NebBigHorn is offline
Vehicle: 2012 Dodge Ram
2010NebBigHorn is on a distinguished road
Default 35x12.50 Tires on Stock 20" rims
Does anyone know if 35x12.5 or 33x12.5 tires will fit on the stock 20 inch rims? I am looking at getting new tires and it appears that these sizes open up a lot of other options that the 275/65 20's don't have.
also, I am getting a Daystar leveling kit installed for 400 including the alignment. Is this a good price? They are charging me 160 for the 2 inch kit and the rest is labor and the alignment.
Thanks for the help.
Mopar Leveling Kit, N-Fab Steps, 295\60\20 Trail Grapplers, K&N CAI, Hypertech Speedo Calibrator
Old 02-08-2011, 02:22 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The stock 275/60R20's are 10.8 inches wide, so you are basically going 2 inches wider. I know most of the 12.5 tires I have seen are on 10" wide rims, which I doubt the stock wheels are. The height being 33 or 35 doesn't matter, it's the width that wll get you. Not to sure about this, but it might work! Hopefully a more precise answer is coming
Old 02-08-2011, 02:29 AM
916Timmy's Avatar
Rep:1443
So it looks like you are in luck. I checked some tires on TireRack.com to see what size rim they would fit on.....they said 8.5 to 11. SO if your stock 20" rim is 20 x 9 then we have a winner. Just make sure you check the tire that you want to make sure its' width range is good for the 20X9 wheel. Hope this helps! The narrower rim will make the contact patch slightly narrower than lets say a 20X10 wheel.
http://www.tirerack.com/tires/tirete...jsp?techid=198
Old 02-08-2011, 02:56 AM
Old 02-09-2011, 07:28 PM
jdanthony26's Avatar
jdanthony26 jdanthony26 is offline
Vehicle: 2010 Dodge Ram 2500 4x4 CC
Trim Level: Big Horn Crew Cab
Rep:38
jdanthony26 is on a distinguished road
hey ,, i put a a set of 35x12.50x20 Toyo MT's on mine, put a 1/4" spacer in and worked perfect, check ur leveling kit though, some are claiming they are 2.5 or even 2" and they are only gonna give you about an inch. do ur research on what ones your gonna buy, the daystar 2" is only gonna give you just about an inch, i had the 2.5 kit in the front and the 1" in the rear. i was happy with that but then i did a 3" body lift and that was perfect. post some pix when ur done .... good luck!!
Old 02-09-2011, 09:29 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
I tried 305/55/20 (basically 33x12.5) Trail Grapplers and they rubbed on the control arm. I sold them and the guy that bought them put on 1/4 spacers and they fit. I think it may be because they had such aggressive side lugs, you may be able to fit a less aggressive tire of that size. I thinking I'm going with 285/60/20 next, I'm not worried about that rubbing. I wouldn't say 35's won't fit, but it would be a gamble. The taller height of 35's may get you past the control arm and get you clearance.
I have a 2.5/1.5 level kit also.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 02-09-2011, 11:58 PM
libertyfiremedic libertyfiremedic is offline
Rep:54
libertyfiremedic will become famous soon enough
I see alot of people on here going with the Daystar... We don't install them unles the customer asks specifically for them. I like the Readylift product better. It gives you a true lift where the poly is subject to compression, weather, etc. We install ours for $350 with the alignment.
Old 02-12-2011, 09:57 AM
donn12 donn12 is offline
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
donn12 is on a distinguished road
I think the tires will be too wide
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 88 01-08-2015 02:26 AM
larger tires on stock 20 inch rim Bighorn5.7 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 10-13-2010 09:02 PM
Winter Rims and Tires? RAM2009 2009 Dodge Ram Forum 2 08-10-2010 07:44 AM
Tire thread for stock 20" rims hokunahooikaika Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 08-11-2009 08:44 PM
20" Wheels W/Studed Snow Tires - New! boisejim Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 17 03-12-2009 10:22 AM
