Old 02-08-2011, 11:33 AM
CovertRam's Avatar
CovertRam CovertRam is offline
Vehicle: 2014 Ram 1500 4x4 CC 5.7
Color: Blue Streak
Rep:83
CovertRam will become famous soon enough
Default Curt Front Hitch
Hey folks. I ordered the Curt front hitch for my 08 Ram. Part number 31320 It arrived a couple days ago.
Here are some pictures before the install. I'll post pictures during and after install.
I plan on using it for my winch mount.
Old 02-08-2011, 12:17 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Very nice! I want one for my truck as well, to put a portable winch mount into!
Nice stuff, can't wait to see the install.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-08-2011, 12:18 PM
Rep:1909
Curt makes good stuff. I have a couple of their drop hitches.
Old 02-08-2011, 01:01 PM
Rep:2657
I miss having a front hitch, it comes in real handy for things like pushing a trailer down a driveway or boat ramp & i could get 5 cents a mile more for my work, checking bridge & wire clearance
[IMG]
Old 02-08-2011, 01:11 PM
Rep:1909
[IMG]
That looks like a redneck CB antenna....
Old 02-08-2011, 01:44 PM
Rep:2657
heheh
i never thought about that, yes it does
actually, we raise those poles 3" higher then the actual over height load that is behind us about an 1/8th mile. If the pole hits an overhead obstruction, we get on the CB radio & warn the truck driver to Stop before proceeding,
The Authorities tend to get upset when a bridge or telephone wires get knocked down by something like this
[IMG]
Old 02-08-2011, 01:50 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
Very nice. What type of winch are you planning to go with?
I have a Warn 12k lb series for the front and 9k lb series for the rear. Love them. They work great and very reliable under all types of situations (hot, cold, severe angles, etc.). If you have not used winches on vehicles before, keep in mind they draw signifcant amps from your battery and alt - they can draw as much as 400-500 amps under load. Best to keep truck running when using it.
Love to see pics once you have installed your hitch adn mounted your winch on.
Old 02-08-2011, 02:00 PM
Rep:2657
I believe the 2011 Rams now have stepped up the battery CCA to 750
600 amps was a bit to light duty
Old 02-08-2011, 03:34 PM
CovertRam's Avatar
Color: Blue Streak
Rep:83
Thanks for all the comments folks
I have ran a winch before when I had my TJ. Eventually what I would like to do is run a second battery where my airbox was. My air intake really freed up some room under the hood. I have a small system in the truck and I find that the voltage drops quite a bit when I turn it up. So to help with the current the winch will draw and the voltage drop from the stereo I think adding a second battery will be the best plan.
I don't have the winch yet but I have been looking at Runva winches. For the price and the amount I will use the winch they makes sense.
Old 02-11-2011, 01:21 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
A capacitor might help you with your voltage draw for the stereo and not tax the battery as much, especially if you are adding a winch.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
front mount hitch for backing into a driveway? austaz Towing 10 01-06-2011 10:18 PM
Front Mount Hitch. crram1500 Towing 10 04-28-2010 11:06 PM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 08:26 PM
