Old 02-08-2011, 04:17 PM
beerad4's Avatar
beerad4 beerad4 is offline
Trim Level: TRX4
beerad4 is on a distinguished road
Default 4WD Problem! Help!
OK, had to put the truck in 4WD low this morning to get into the driveway. I turned it off and went inside. When I went back out a couple of hours later, I was greeted with a blinking "Check 4WD", and both ABS and traction control lights are constantly on. I have turned the truck off and went through the 4WD again thinking it may have needed to be reset. No Luck. Any help would be great! Thanks!
Old 02-08-2011, 04:34 PM
heffs03mach1's Avatar
heffs03mach1 heffs03mach1 is offline
Vehicle: 2010 dodge ram sport 4x4
Trim Level: sport
Color: blue
Rep:99
heffs03mach1 will become famous soon enough
Take it for a spin and maybe it will reset
Old 02-08-2011, 04:38 PM
beerad4's Avatar
Trim Level: TRX4
drove about 5 miles. Nothing reset. Thanks for the suggestion though!
Old 02-08-2011, 05:17 PM
klx klx is offline
Vehicle: 2010 Ram 1500
Rep:27
klx is on a distinguished road
Hello it's a wheel speed sensor just had my truck do the same thing, abs light on,traction control light on, cruise control not working. took it to dealer right rear wheel sensor bad changed it about 1-1/2 hour wait all good now common problem mine crapped out around 6500 miles
Old 02-08-2011, 05:29 PM
AKFossil's Avatar
AKFossil AKFossil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:57
AKFossil will become famous soon enough
Curious why 4 Low would be used to get into a driveway, seems odd.
But after you took it out of 4 Low did you have the truck in neutral and let it sit there till it came all the way out of 4 Low?
Also did you try to re-engage 4 Low and then disengage it to see if that helps?
2010 Dodge Crew Cab Inferno Red: HID Low Beams & Fog Lights 6000K, LED Interior Lights, LED License Plate Lights, Black Nerf Bars, AVS Bug & Window Deflectors, K&N Drop In Filter, WeatherTech Floor Mats, Goodyear Wrangler Silent Armors, MagnaFlow Muffler
Thinking about: New Wheels, and leveling kit.
Old 02-08-2011, 05:31 PM
AKFossil's Avatar
Color: Inferno Red
Rep:57
Oh if you have a garage try parking your truck in it over night and see if maybe some ice built up on the wheel sensors.
Old 02-08-2011, 07:38 PM
beerad4's Avatar
Trim Level: TRX4
AKFossil-
Good catch..I was in 4WD not 4WD Low..my bad
Old 02-08-2011, 11:52 PM
AKFossil's Avatar
Color: Inferno Red
Rep:57
Man I was hoping you had a driveway mud bothers envy
Old 02-09-2011, 04:11 PM
beerad4's Avatar
Trim Level: TRX4
UPDATE: Dodge dealership has had my vehicle all day and said it may be returned sometime tomorrow. Apparently they cannot locate the problem. They said they have checked all of the wheel speed sensors, and they all check out ok. They are thinking it may be a short somewhere or the wiring harness...this sucks the truck has a little over 3,000 miles on it.
Old 02-12-2011, 06:05 AM
Momud Momud is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Crew C
Trim Level: Slt
Rep:22
Momud is on a distinguished road
At least they see that there is problem and not the almighty, "We can't reproduce the problem, bring it in the next time it does it" routine.
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 12:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
Gear Problem 07Ram 5.7L V8 Specific Topics 5 02-13-2009 07:58 PM
