'01 Dodge Ram 4wd shifting problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-08-2011, 10:52 PM
CloneSaw CloneSaw is offline
Vehicle: 2001 Dodge Ram
Trim Level: Sport 4x4
CloneSaw is on a distinguished road
Default '01 Dodge Ram 4wd shifting problem
Well...........
I have a snow plow on my truck, which i use the 4wd quite often. I have never had a problem with the truck shifting in or out of 4wd. Then the other day I tried shifting into 4 high, nothing. the light on the dash didn't light or the 4wd didnt engage. I would like to think the problem is NOT in the transfer case, rather somewhere in the vacuum system......
Any ideas or things to check,look for?
Thanks
Old 02-09-2011, 12:06 AM
Try and verify that the front driveshaft is spinning when in 4x4 . You may need a 2nd person for that test . If so , you should have 2 vacuum lines going from the transfer case to the front axle . That makes the front axle lock in when the t-case is engaged in 4x4 . Check and see if their in tact and not broken . Their plastic so with some age on them they have a tendency to break easily .
Old 02-10-2011, 01:25 PM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
Had the same problem on my old 01 a broken vacuum line near the transfer case was the culprit.
Bodine
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 01:10 AM
New to the Forum- Dodge Problem mcleanchevy17 Newbie Checkin! 12 04-09-2010 05:33 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
Fuel problem w/90 dodge ram mowman1 Newbie Checkin! 5 01-18-2010 07:46 PM
96 Dodge Ram park light problem stormcr0w Electrical 5 05-28-2009 04:33 AM
