Power locks blow fuse - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 02-08-2011, 11:07 PM
Mopar4me Mopar4me is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Color: Patriotic Blue Pearlcoat
Rep:90
Mopar4me will become famous soon enough
Default Power locks blow fuse
My power locks will occasionally blow my fuse and I don't know why it happens. I've put in a stronger fuse but it's only a band-aid for now. Also the driver side rear lock will occasionally stick. It always locks but sometimes won't unlock. Are these events related? The fuse doesn't blow everytime the lock fails, so it seems to be a different issue. Any help on either problem is appreciated. Thanks in advance.
Old 02-09-2011, 12:01 AM
That would be a good place to start . Seeing it doesn't blow the fuse all the time , it's gonna be tough to narrow it down . I'd unplug the suspected bad lock actuator for awhile and see if the problem disappears . If it does you know where the problem lies .
Old 02-09-2011, 12:18 AM
Rep:90
Thank you, I will try that and I'll also replace the original fuse while I'm at it, to go back to default.
Old 02-27-2011, 09:12 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
yes, definitely go back to spec fuse. if the fuse blows randomly, whatever component that is part of the circuit is dying a slow death and if you have the bigger fuse installed, time to get out the hot dogs and roast em by the fire.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-11-2011, 01:32 PM
Rep:90
I figured out that the problem is likely with the driver side rear door lock. It occasionally gets stuck whenever it feels like it and I believe that is blowing the fuse. I am going to put the stock fuse back in and disconnect that door lock and see what happens.
Old 04-30-2011, 04:26 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Theres deffinetly a short in you system. Pull your door panels off and inspect all your wires make sure you pay special attention to the wire loom in your door jam, those tend to get caught up thru time.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 01-19-2017, 11:09 PM
jamesnev jamesnev is offline
Vehicle: 2011 ram 1500
jamesnev is on a distinguished road
Im having the same issue, the fuse was blown, but when i went to put the new one in, it melted soon as it touched the contacts.
all 4 of my locks don't work from the driver side, the passenger side, or the key fob.
any ideas on where to start? planning to check wire looms on each door, but other then that, i don't know where to go
Old 01-29-2017, 12:58 AM
striker2237's Avatar
striker2237 striker2237 is online now
Vehicle: Ram 1500 "Supermagnum"
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver (PS2)
Rep:203
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
There is a ground strap fault somewhere on the truck cab leading to a short.
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
Power Door Locks hemi05 Electrical 18 04-05-2017 12:38 PM
What controls the front power windows, door locks? rlandon Electrical 6 11-11-2014 04:35 PM
ST Power window, locks, and power rear sliding window upgrade deervalley Electrical 21 06-22-2011 08:46 PM
New guy from NY needs help with power door locks! awolb72 Newbie Checkin! 14 12-05-2010 05:07 PM
Power windows power locks 96 Ram rbarufaldi Electrical 0 10-11-2009 09:21 PM
