Old 02-14-2011, 07:04 PM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Just a thought, but wonder if it had anything to do with how fast you may have been going when switching form 2wd to 4wd. I think they advise not going more than 3 mph especially if going into 4wd low. Perhaps?
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Old 02-14-2011, 07:20 PM
bucholj's Avatar
bucholj bucholj is offline
Trim Level: Bighorn
Rep:26
bucholj is on a distinguished road
I did not switch to 4wd until after the light came on and I was trying to get it to go out.
Old 02-14-2011, 07:25 PM
Rep:20
I will have to look at this too...something about a light coming on when no slipping sensed.
knsram
Old 02-14-2011, 08:20 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
@ knsram
bull low they recommend under 3mph i believe and 4 high is under 55mph if my cranium serves me right
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 02-14-2011, 10:43 PM
space85 space85 is offline
space85 is on a distinguished road
I had to change the service date to Saturday I will update you with an answer as soon as I find out. Also I was not in 4wd and was not trying to get into 4wd but again once I find out I will let you know
Old 02-15-2011, 10:54 AM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
When I backed out of my driveway I was on a small peice of ice and when I put it into drive the front end sounded like the drive shaft was knocking. Ive only had FWD cars in the past so I dont know anything about cars with drive shafts.
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
Old 02-19-2011, 05:55 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Originally Posted by space85 View Post
So I was driving my truck the other day in 2wd and stopped at a light. The roads were icy so when I pulled forward my truck made the grinding noise and the slip light came on which is normal by then I heard a ding and the 4wd service light came on. I pulled over turned the truck off and started back up and the light was gone. I even switched from 2wd to 4wd with no problems and the light never came back on so I just disregarded the warning. Well the other day the same thing happened again an now I'm a little worried. Is this a common problem and does anyone have any idea of what it could be. My truck has the 5 position transfer case if that makes a difference.
I had the exact same problem with my truck and the light. Not any noise that heard. I had just pulled onto a dry street accellerating normally. I was very cold though. The dealer said no error code was found.
Old 02-19-2011, 11:28 AM
Mr.G Mr.G is offline
Vehicle: 2014 1500 Ram 4X4 Crew Cab
Color: Maximum Steel
Mr.G is on a distinguished road
Same thing happened to me. New truck 800 miles, took a sharp slow turn in 2wd and the inside rear wheel slipped a bit. The service 4wd light came on. Backing in my drive way I needed 4wd but it wouldn't engage. Shut truck off and restarted light was off and 4wd would work again. Very weird.
Old 02-19-2011, 06:50 PM
I went to the dealer today and they said they couldn't find any saved codes and that I was probably just a glitch
Old 02-19-2011, 08:06 PM
bucholj's Avatar
Trim Level: Bighorn
Rep:26
Thanks for the update Space85, I was wondering what you found out. I'll skip taking mine to the dealer then. I have not had any more episodes with the light.
2011 Ram 1500 Service Manual Cdncarnut 2011 Dodge Ram Forum 1 01-05-2011 10:16 PM
service 4wd/esp light Black Laramie 2009 Dodge Ram Forum 1 12-09-2010 04:44 PM
Dodge Ram Service Manuals 1990-2007 DaveDees Dodge Ram Knowledge Base 11 09-12-2010 10:28 PM
Chrysler takes the wraps off of 2011 Dodge Durango DaveDees Automotive Industry News and Dodge Press Releases 12 09-08-2010 05:43 PM
1998 dodge ram overdrive light nitrofish640 Electrical 3 07-13-2010 07:45 AM
