Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 02-09-2011, 01:42 PM
luv2gomudn's Avatar
luv2gomudn luv2gomudn is offline
Vehicle: 98 Ram 1500 4x4 shortbox
luv2gomudn is on a distinguished road
Default 4 wire connecter on R taillight
98 1500 4x4, wires pulled out of plug and need advice where to get a plug or which holes to put them back into...has 1 green wire and 3 white wires...
Old 02-09-2011, 10:25 PM
Matt1924's Avatar
Matt1924 Matt1924 is offline
Vehicle: 1999 Dodge Ram
Trim Level: SLT Lariat
Color: Red/Silver
Matt1924 is on a distinguished road
Hey there, you should be able to pick up a connector at your local auto parts store. At least I would assume that since you can also get your lamps there.
Old 02-09-2011, 10:49 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
You could look at the left pigtail and see if that will help you figure the right out. The wire colors should be the same for both sides.
Good luck.
Old 02-10-2011, 09:59 AM
luv2gomudn's Avatar
truck was a rebuilt wreck and wires are different colors. I think they used whatever they had. Will try NAPA or calling around salvage yards...
luv2gomudn's Avatar
Its a 98 with 2000 cab and 99 box
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 16 07-02-2016 05:36 PM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 04:39 PM
HID INSTALL SOLUTION for anyone that cares silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 3 08-26-2013 08:54 PM
2002 audio wire colours (head unit) Dann Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 02-14-2010 12:16 PM
